Weird problem with headlights (JDM ITR)
Old Jul 27, 2010 | 05:19 AM
JDM_EH2's Avatar
Default Weird problem with headlights (JDM ITR)
I just installed new bulbs in my JDM HIDs and now the passenger side low beam only stays on for about 20 seconds at a time. I thought the bulb blew at first, but everytime it hapepens all i do is flick the lights off/on and it works for another ~20 seconds. Any idea on what's causing this? They're cheap ebay bulbs because I wasn't sure if the ballast was still good...not sure if that matters?
Old Jul 27, 2010 | 11:21 AM
Tekkaboy's Avatar
Default Re: Weird problem with headlights (JDM ITR)
Test it with a known good bulb.
Old Jul 27, 2010 | 12:16 PM
sheekdude's Avatar
Check the fuse first...
Old Jul 27, 2010 | 12:28 PM
94rs-turbo's Avatar
from my experience your having a issue with your ballast, same as the other guy. so time to test them. swap bulbs and ballast on eachother. it a process off elimination on what isnt working correctly
Old Jul 27, 2010 | 01:13 PM
sheekdude's Avatar
If not, i might have oem jdm ballasts for sale. Be advised, the left is different from the right!
Old Jul 27, 2010 | 03:18 PM
soulassassin13's Avatar
.... you are still selling these?
Old Jul 28, 2010 | 12:52 PM
JDM_EH2's Avatar
Update: It was the cheap eGay bulbs. The connector for the ballast wasn't staying on it no matter how I tried it. Switched back to the Phillips bulbs and the connector went right on and the lights work perfectly now.
The whole problem which I thought was a bulb, turned out to be just the little 10 amp fuse for the passenger side headlight. And thinking about it I know exactly when it happened. Oh well I lined up my bumper and headlights a lot better while I was at it
Old Jul 31, 2010 | 06:48 AM
sheekdude's Avatar
Like i said before... 'Check the fuse first'
redline870
May 5, 2008 04:26 PM
beaneg6
Nov 8, 2005 04:11 PM
iMPorT_kULtuRe
Aug 21, 2005 04:58 PM
MR Dan
Jan 13, 2005 06:38 AM
Wicked671
May 14, 2003 01:29 AM
