simplify an ek rear disc swap please
i went to pick n pull today and saw a del sol, eg and a bunch of 94+ integra's with nice sexy rear disc brakes, master, e-brake cables, everything there. i've tried the search button and found the greatest rear disc swap guide ever..... about the 5th paragraph i got lost. a guy at pick n pull said that 98+ had larger rear brakes or some mess like that.
if someone can give me a direct list of which of these 3 will work and exactly what parts i'll need that'd be friggen awesome!!!!!
i'd like to go get the parts and do it next week
Cool Cool Island Breezes. BOY-EE
90-01 integras
88-00 civics
All del sols
If they came with a rear disk, it's all the same. EXCEPT the calipers and lines and E-brake cables.
The trailing arms, hubs, and rotors are all the same.
For a 96-00 civic, you need 99-00 civic E brake lines. Or you can adapt the 94-01 integra lines to fit. It's semi easy to adapt them.
Your first choice of a donor car will be a 99-00 Si. Everything will work with no issues.
Next would be a 94-01 integra or 92-95 civic. Take the calipers and hydraulic lines with you.
The only reason I'm not including the Del Sol in the above statement is that I don't know very much about the Del sol lines/calipers. Never used them. I'm almost positive it's all the same as the 94-01 integra or 92-95 civic, though.
That's as simple as it's going to get.
88-00 civics
All del sols
Del Sol parking brake cables are weird, they only fit Del Sols, its not a length issue, the cabin end of the cable is just completely different. Other than that everything should be the same.
johnny hatchback
11
Mar 31, 2003 07:11 AM
