'92 Accord nuisance oil leaks
Hi,
I'm noticing a couple of oil drips under my car every day. Maybe 4-6 drops, several different places. I know it isn't the valve cover gasket leaking. What are the most probable locations of the leak?
Thanks
Thanks
#1 Oil Pan Gasket/Oil Pan
Distributor Shaft Seal
Oil Pressure Switch on Back of Head
Oil Filter
Drain Plug
Crankshaft Rear Main Seal
Oil Pump
Transmission Axle Seals (Manual Trans unless it's red like ATF then it could be Auto Trans)
Oil Filter
Drain Plug
Oil Pump
Ser1N
Jan 26, 2020 02:26 PM
