94 coupe civic h2b h23a qsd part out. Nj will shop
I'm parting out my h2b coupe. Text only. I barely be on the site. I'm in central nj. Everything is fresh. No half *** ness 9084871848
Vins n video of motor running will be up on you tube later when I get out of work.
This is a short list.
H23a vtec long block. With revisit from engine depot perfect compression I thunk 215 psi all across longblock 750$
Qsd kit. Plate half shaft slave cylinder block driver bracket. Flywheel spacer. 650$
B16 trans with phantom grip LSD. Make offer.
Competition clutch stage 4 b series with under 100 miles. Still have box 300
Del sol seats blue with grey stripe lil tear on driver left but sewed up 150
Fidanza 7lb b series fly wheel 125
Hytech replica headers with flex pipe. Fresh 250
Rc 310cc injectors 150
Polished aem h22 fuel rail 100
Dh racing 69mm tb with brand new omni tps sensor 150
H22 skunk 2 manifold with iac n oat sensors 225
Aem aluminum alternator pulley 40
Alluminum radiator half size DUAL core with fan 100
Apexi N2 2 1/2 exhaust real apexi for coupe/4 door 200
Ecu chipped and socketed with street tune for h23a with my mods 150
B series mounts with inserts 50
B series shift linkage with red prothane inserts and weighted skunk 2 rep shifter 75
B series axles new 40 each or 75 both
B series starter 50
Basic intake with blue intake 2.5 inch 40
H22 type s cams with blue skunk 2 gears 250
Prob alot more just ask. Names weezy 9084871848. Please text only. With any questions or pics.
B series starter 50
NothingButBoost
Jan 13, 2015 08:19 AM
joshc697
Jan 13, 2009 04:37 PM
