crx loss of power around 3k rpms
so after may car sat undriven for a couple days i go to drive it and after it warms up i notice it losses alot of power around 2800-3300rmps and it seems to get worse the more i drive it. it only seems to do it when i got the throttle at about 1/4-1/2 but goes away when i put it to the floor. it will go good if i hammer on it but if i let off the gas a lil bit it looses like all power. so i took the spark plug wires out and notice that sparke plug tube #3 has oil in the bottom of it all around the spark plug. so i get that all cleaned up and fix the spark plug tube gasket. i go to test drive it again and its still doing the same thing so i figured that the oil around the spark plug must have ruined the plug so i replace all four with new ngk v-power plugs. its still doing to same thing. theres no CEL and its not throwing any smoke and it idles fine. im hoping someone can help me out i miss driving the crx. btw it has a z6 swap and runs perfect and ive tried swapping out the plug wires.
deraj1986
May 30, 2010 01:28 PM
inegma29
14
Apr 16, 2008 05:28 PM
HTn00b
43
Nov 8, 2006 02:35 PM
