HELP!!!!16x8 +20 on integra
ok guys if u guys can please help me get the correct tire to make them fit with out rubbing issues and make them look stretch a little not drastic also i know i need roll fenders and camber kit so that i know but just need help on what tire size should work best thanks
wheel specs will be
sportmax 521
16x8 +20 offset
wheel specs will be
sportmax 521
16x8 +20 offset
The only size tire you can use safely on 16x8 wheels on an Integra is 215/45-16.
This is why 16x7 is a better width for an Integra. With 16x7, you can also use 205/45-16, which is less likely to rub (but cannot be mounted safely on 16x8, which is too wide for that size). You can also use 215/45-16 on 16x7.
