(PA)FS/FT~EF~EG~EK~DA~PARTS~*PICS*
Hey im Looking to get rid of some things...To Fund My 95 Ex Coupe LS-T
I Will Take Trade's Ill put a List of What im Looking for...If Need more Pics PM-ME OR Call-724-984-6442 (Zack)
EVERYTHING IS OBO..I THREW REASONABLE PRICES ON HERE...BUT WILL WORK WITH YOU...
~OEM PARTS~
~EF~EG~EK~DA~
92-00 SOHC Civic Full A/C System..Worked Perfect..Includes...All Lines(Uncut)~A/C Rad/wFan~Bracket&Pump/W Newer Belt~A/C Condenisor By washer Fluid~That core that goes next to heater Core...its 100% Complete...$75.00+Shipping
88 Civic HatchBack Front Bumper...Good Condition..Just couple Screw Holes...$20.00+Shipping
96-00 Civic 4 Door Rear Bumper..Flat Black...Good Condition...$30.00+Shipping
96-00 Civic 4 Door Taillights..Inner&Outer...Mint Condition....$55.00 Shipped
96-00 Civic Coupe Taillights...Inner&Outer....Really Good condition..$45.00 Shipped
99 Integra GSR Coupe..Carbon Fiber Fakes...Taillights...tiny crack in corner..DOES NOT LEAK OR FILL WITH WATER...$20.00+Shipping
94-01 Integra LS Coupe...Side Skirts...Good Condition...$35.00+Shipping(BOTH)
94 Integra Steering Colum..ABS...Includes ignition/w Key in it...Turn Sig&WASHER Switchs...Great Condition...(does not include wheel)....$60.00 Shipped
88 CRX SI TailLights...Both Sides&Middle...Mint Conditon...Ithink the harness are on them...$60.00 Shipped
96-00 Civic Front Grill Piece(White)...$25.00 Shipped
94 Integra LS Power Steering...Rack Pinon...Does Not include..Lines or P/S Pump...Worked Great...$40.00 + Shipping
95 DELSOL SI...5 Speed Gauge Cluster...202K Miles..(Mint)...$50.00 Shipped
97 Civic 4 Door Driver Side Window Glass...$10.00+Shipping
88 Civic HatchBack...Gray/Black Door Panls...(Fair)....$20.00+ Shipping (Both)
92-95 Civic Hatch/Coupe~Gray/Black Passenger Side Door Panal(Good)$15.00+ Shipping
92-95 Civic Gauge Cluster (AUTO) Dunno Mileage..(GOOD)..$30.00 Shipped
97 CIVIC 4 DOOR ANY TAN INTERIOR PIECES YOU NEED LET ME KNO ILL GIVE YOU A GREAT DEAL..ALSO GOT REAR SEATS...
94 Integra Coupe Passenger Door Panal (Black) (Fair Condition)..$12.50+Shipping
97 Civic 4 Door Side Skirts...White Primer...(Great Conditon) $35.00+Shipping (BOTH)
92-00 Civic Cruise Control Unit...Includes Throttle Cable for it...88k Miles..$32.00 Shipped
~~~OEM+Aftermarket Engine Parts~~~
B18A/B/C~B16~B20~Comp Stage 2 Pressure Plate(HYDRO TRANS)..(RED) Great Conditon...Ihad on my B16 for 2300 Miles...Paid $245 For press pl8&Clutch...Ill take $60.00 Shipped
B18C1 GSR OEM Flywheel+OEM Replacement Pressure Plate 8k Miles...$60.00+Shipping(BOTH)
D15B7 OEM 4-1 Iron Header....No Rust Holes or Scraps...$10.00+Shipping
D16A6 PGMFI OBD0 Intake Manifold..Complete..Includes OBD0 RED Injector Plugs (From A20 Accord)...$40.00+Shipping
D15B7 Intake Manifold...Bare..But Does Include Fuel Rail...Can Put OBD1 Injectors in For $25.00 Extra....$10.00 +Shipping for Mani
D16Z6 OEM Fuel Rail...Can Polish For $30.00 Extra....$15.00 Shipped..Includes Crush washers&End Bolt
92-95 Civic OEM Air Intake..Tube&Box&Filter...$35.00 Shipped
94-01 Integra LS/GS/GSR OEM Air Intake...Tube&Box/w Filter....$40.00 Shipped
B18C5 Type-R Oil Pump..I Used on my Ls-vtec for 1500 Miles &Bought New Motor &Pated n/a out....Worked Great had 100 Psi Oil press...Retail $120.00
Ill take $65.00 Shipped
B18B1 OEM Crank Pulley/Harmonic Balencer...(NO CHIPS!!!)Lmao..Hard to find no chips...But great Condition....$40.00 Shipped
(4) B16B PCT Pistons (2) Are In Perfect Condition..Other(2) One Is Melted&Other has metal melted to it...But can order 2 for $30 Each....All on Good B18A/B Rods Great Condition...$50.00 Shipped
D16Y8 Pistons&Rods...103,000 Miles...Good Condition...$45.00 Shipped
B18A1 OBD0 Intake Manifold...Does Not include..Fuel Injectors~Fuel Rail~TB~IAC~Its Bare...$20.00+Shipping
B18A1 Lite Weight Crank Pulley..Unknown Brand...Silver...(FAIR Condition...$22.00 Shipped
B16A JDM OBD0 PR3 Ecu...Great Condition....$95.00 Shipped
D16Y7 OBD2 P2E ECU...Manuel...$45.00 Shipped
D15/D16 HF Manifold...Used for Turbo With adapter Plate...Its in Mint Condition...No Rust or anything...Still got 1 Wire Oxygen Sensor &Mounts on it...$45.00 Shipped
TD04H (T25) Eclipse Turbo..Needs Rebuilt..Includes..Exhaust Housing with DSM 4 Wire Oxygen Sensor...$40.00 Shipped
DSM Stock Side Mount Intercooler...Fair Condition....Great For Sleeper..0-8 Psi...$25.00+Shipping
DSM Stock Blow Off Valve..(Crushed)...Good Conditon...$20.00 Shipped or 25.00 Shipped with Flange For charge Pipe
(2)88-00~D15/D16 SOHC...Driver Side Axle's...Great Condition Both got Under 5k Miles...Still have stickers on them...Boots are perfect...$25.00+Shipping Each
H22A JDM OBD2 Injectors...25,000 Miles...Includes Plugs...The Smaller injectors..Not size of normal honda injectors...345cc....$55.00 Shipped
91 Integra B18A1 Injector Resistor Box/w Plug...Great Condition...$22.00 Shipped
B18B1 Upper&Lower Timing Belt Covers..Both Mint..(BLACK)....$20.00 Shipped
B18C1 Hydro Tranny Speed Sensor....18k Miles...Includes Plug...$45.00 Shipped
B18A1 Cable Tranny Speed Sesnor...Great Condition...$22.50 Shipped
B18A1 Thromostat Housing/w Thromostat&Goose Neck&Gaskets...$20.00 Shipped
96-00 Civic Pillow Mount...Great Shape..Solid...No rips...D16Y7/Y8...$37.00 Shipped
*SOHC...Upper&Lower Timing Belt Cover...Good Condition...$20.00 Shipped
front Mount Oil~Tranny~P/S Cooler...$17.00 +Shipping
*D16Z6 Fuel Rail/OEM Regulator...$15.00 Shipped
*D15B7 FUEL Rail/OEM Regulator...$13.00 Shipped
*95 Civic EX Front Driver..Lower Control Arm...$20.00+Shipping
*94 Integra Gsr Front Lower Control Arm...$25.00+Shipping
*94 Integra LS Coupe...Full Sunroof Assembly..Everything you See..Worked Perfect When took out...$50.00+Shipping
Advance Flow engeringg...Aluminum Volcity Stack&6"Filter..Made great Power On my civic...$50.00 Shipped
97 Civic 4 Door...Trunk Lid...Mint Condition...(FLAT BLACK)..Does Not include Tailights...$35.00 Picked up...
D15/D16/B18 OBD0 MSD DISTRIBUTOR CAP...lIKE NEW..$25.00 Shipping
Will add more
~OEM PARTS~
~EF~EG~EK~DA~
Will add more
