GSR or B16 CTR
another hint...bigger engines make more power for a longer period of time in the power band, not just some little blip on a dyno graph showing a large hp number like smaller engines do
A broad power band performs wonders
oh. obd1 is very tuneable and obd2 isnt as tuneable like obd1. so you must decide if you are going all motor or boost. if you go boost on that gsr get the obd1. as i stated before obd1 is better for tuning and obd2 has limitations
this thread is a fail, it all depends what do you want to do, if your going to boost your engine, gsr is better, if your just going to swap it, ctr is better,
if your planing to trade your car after the swap that's a whole other story...
it all depends if your going to keep it forever or sell/trade your car..... which most people do anyways....
There is nothing wrong with an all motor gsr swap, don't mislead people...it makes more torque. A torqueless B16B is no faster all motor stock for stock
Get the b16b swap it comes with jdm LSD 4.7fd tranny and gsr doesn't come with LSD, 4.4fd. The b16b is high revving 8400rpm with intake side dual valve springs, gsr doesn't. But If your not getting a complete swap I'll just said yea get the gsr.
My b16b ek9 beats gsr's at the track as well as type r integras. i've done 14.5 on the 1/4 mile, a time some gsr's have never seen.
and the stock b16b has a power output of 185hp, while the b18c gsr has 170hp from factory.... less hp on the gsr's end.... both are good engines so you don't mislead people. i think the b16b is a great platform to start with, after all its jus a destroked b18 block, which can be turned to 1800 wit a simple change of crank and rods.
I am a noob when it comes to hondas but correct me if I'm wrong but GSR's are not JDM at all. Unless I'm mistaken the only thing that would be like a Japanese GSR is the Integra Si Vtec.
you guys are hilarious with the arguement over a b16b or b18c....personally i'd go with the b18c for two main reasons. 1. Price, you can buy a b18c and mod it some for the price of a b16b and be over 185hp. 2.Potential, the b18 has way more modification potential
$kreech, torque may not be what wins races, but torque is what makes your horsepower and moves your car. also your ek9 may beat integras that's because weight is a big factor
OP its totally up to you, people are going to give you mixed feelings all day. If you want cheap power do a b18b turbo which will beat both the b18c and b16b in stock form with minor bolt ons....if you want beasty torque and power of a b18c5 then do an H22a or F20b swap mated to a bseries transmission......if you want more potential yet then do a k20 or k24/k20 swap or ls/b20 vtec.....and if then yet you are still not satisfied then I guess a J swap is in order for you
good luck
good luck
good luck
good luck
its all up to the OP and wat his future plans are, but i would definitely go for the b16b... it has more aggressive cams, higher comp pistons, PnP head and dual valve springs already. to make more power jus slap in a b18 crank and rods and reuse the ctr pistons and head. to make more power in the gsr u would have to upgrade cams (which means upgrade valve train as well) and put in higher comp pistons, which would take more money than upgrading the b16b. this is my point.
the b16b is the same deck height as the b18c only diference is less stroke and more compresion on the piston dome if you were to trow a b16 head on a b18c and some ctr pistons you would have a similar engine exept for the compression would be much higher cus of the longer stroke on the b18c. but other than that they are the same block exept the internals offcourse
I my self would go b18c and invest in some ctr pistons and ctr cams and a b16 trany then it would be real fun
and this is according to who? your own opinion? the gsr has more torque yes, but its not torque that wins races but a matter of other variables as well.
Ha ha, everybody always seems to think that the particular engine in their own car is the fastest, LOL Did you foret we were talking about JDM engines here, LOL The JDM B18C gsr has the same compression as our usdm ITR at 10.6:1 and makes 180hp and 130ft lbs tq! Here is the really important part....not only does it makes this good numbers, but makes it for a much "broader" stretch of the rpm range, not just a hickup like the smaller B16B which has only a 5hp blip of peak power at max rpm and "way" less torque
I have owned 2 B16B's...they are ok, but i got rid of them for B18C's and will NEVER go back! As far as racing goes, i know your car is peppy, it would be even faster with the larger B18C
In Japan they had two versions of their B18C
- the ITR with 11:1 compression and make 200hp
- the Honda Integra SiR with B18C gsr with 10.6:1 compression with 180hp
