94 civic radio shuts off when turn signal used
It is an aftermarket cd player, works great until the left or right turn signal is engaged, then
the radio just cuts out and keeps attempting to turn on until the turn signal is off. Is there an
easy fix , I assume somebody wired something with the radio into the power supply for the
turn signal?
turn signal?
ha, the easiest and only fix is pull the radio, and wire it correctly, check the ground and make sure it has proper continuity, ensure that the constant and switched 12v is running to the correct locations. I'm guessing the installer did not use a wiring harness and hacked the factory harness.
coupeaddix93
Mar 15, 2012 06:43 PM
