Badge removal holes
Old Jul 25, 2010 | 03:03 PM
lunareg's Avatar
Default Badge removal holes
I was curious if theres anything out there or a good way to fill the holes left from removing the H badges. I knows theres the obvious bondo/paint combo. But im more wondering if theres some sort of plug, or if anyone has any success with filling the holes without some body work involved. I know they sell those plugs for the front license plate holes for example.
Old Jul 26, 2010 | 05:11 AM
Stay*_*low's Avatar
Default Re: Badge removal holes
Stuffing the holes with bondo and then painting it probably won't last long. It seems like the bondo would start cracking and come out. Do you have access to a welder because you could shave it.
Old Jul 26, 2010 | 05:21 AM
Rbk's Avatar
Rbk
Just get the holes welded up.
Filler will just crack
Old Jul 26, 2010 | 12:13 PM
lunareg's Avatar
true true. I guess i was trying to figure a temp way to make the holes less noticeable, it is a black car, but i was trying to avoid re-painting for the time being.
Old Jul 26, 2010 | 01:53 PM
TunerN00b's Avatar
JB Weld and a Sharpie?
Old Jul 26, 2010 | 06:32 PM
519JDMKING's Avatar
welding would be your best option. BTW where can you get those front license plate hole plugs?
Old Jul 26, 2010 | 11:20 PM
lunareg's Avatar
sounds like about the only alternative huh, lol
theres a speed shop in chi that has all kinds of stuff like that, I found some on ebay, but they only had blue ones for 00 civics
Old Jul 29, 2010 | 05:14 AM
jksmith's Avatar
por15 makes a Epoxy putty that works great for this stuff
Old Jul 29, 2010 | 10:17 AM
97civic02's Avatar
haha
Old Jul 29, 2010 | 11:53 AM
Duc_du's Avatar
i just paint the emblem black and slap it on. look clean in my opinion. or jb wield, sand and paint?
Old Jul 29, 2010 | 01:16 PM
delsolproblems's Avatar
If welding (the best way to do this) isn't a viable option, a composite filler like fiberfill or almost any reinforced filler will fill the holes. The top painted surface must be ground or beveled to prevent the filler from popping out downward. The same would need to be done to the other side if you were painting the back as well. Either by spreading the filler beyond the holes or by beveling the edge of a hole, you'd be aiming for the cross-section of the repair to look like an "I". You shouldn't have to worry about cracking with an epoxy-based filler on such a small repair since it's not as brittle as typical filler. A very thin layer of regular body filler would be used to level the surface after sanding the fiberfill, then finishing glaze, primer-surfacer, base and clear with all the sanding in between.
CPreston
Paint and Body
13
May 17, 2009 11:59 AM
Riced-EL
Paint and Body
Jan 10, 2009 01:03 PM
standbackimapro
Welding / Fabrication
May 23, 2007 07:08 AM
EvenStar
Mar 23, 2007 09:34 PM
vtec69
May 8, 2002 04:44 PM
