ls/vtec rebuilt s4c tranny and more goodies
Old Jul 25, 2010 | 02:10 PM
96Spec Ek's Avatar
Default ls/vtec rebuilt s4c tranny and more goodies
ls/vtec engine 4000 and I will included the flywheel, rc injectors and intake manifold
97' b18b block cleaned, decked, align honed, and cylinders bored/honed
00' ls crank balanced, micropolished and graphite coated
pr4(ls)rods balanced, shotpeened, big ends resized for arp bolts
rsmachine 81.75 pr3 pistons with hastings rings balanced
Z-10 girdle with arp gsr mainstuds
acl bearings
goldeneagle ls/vtec set with 82mm headgasket
gsr arp headstuds
8mm arp rod bolts
Mfactory magnetic drain plug
00' b16 head (Hot street port and polish, 3 angle valve job done by cccylinderheads.com)
super-tech valvesprings & retainers
super-tech high compression valves
skunk2 pro2 cams
skunk2 cam gears
JG/Edelbrock Victor X 275$
Profab header 450$
RC 440cc saturated injectors 200$
Transmission 2000$
S4C Transmission
obx lsd
Mfactory 4.928 final drive
Mfactory 3.07 1st gear
gsr 5th gear
Gearspeed carbon coated synchros 1-5
New oem bearings
Case powder coated silver vein
450$ Competition Clutch Stg4 6 pad ceramic and
Competition Clutch 8lb flywheel
Fresh bore and hone
Z10 main girdle with arp main studs
Golden Eagle ls/vtec oil line kit
ACL bearings
Crank with the journals graphite coated
pr3 piston on ls rod
engine assembly
All New Skunk2 Valvetrain
2000$
B16 Transmission Build (M Factory 4.928 final drive, 3.07 longer 1st gear, obx limited slip differential, gear speed carbon coated synchros 1-5, and gsr 5th gear.
The tear down
M Factory countershaft assembly
Mainshaft assembly
Tranny casing before picture, before cleaning and being powder coated.
Putting the parts washer to work, thanks Bob!!!
Tranny case powder coated (silver vein) and completely assembled
"Before pics"
CCCylinderheads.com Headwork
Valve 2 Valve and R2VS measuring
Head installed for piston 2 valve measuring and degreeing
Still need to get the manifold bead blasted to clean it up.
Intake manifold 275 and new pro fab header 450
2000 ek hatch for sale 1600$
Old Jul 25, 2010 | 03:30 PM
96Spec Ek's Avatar
Default Re: ls/vtec rebuilt s4c tranny and more goodies
Meant to post this in all motor fs section. Mods please erase
96redEKhatch
34
May 6, 2010 07:09 PM
96Spec Ek
62
Sep 9, 2009 08:25 PM
96Spec Ek
35
Jul 24, 2007 12:17 PM
