Tilton Hydralic Throwout Bearing Install
Old Jul 25, 2010 | 12:58 PM
Mr. Em1's Avatar
Default Tilton Hydralic Throwout Bearing Install
I am looking for pics of how people have gone about installing these kits in their cars. Im not sure exactly where i want/ should place the bleeder screw and such. Any pictures would be great. Thanks guys!
Old Jul 25, 2010 | 02:28 PM
jdm inc's Avatar
Default Re: Tilton Hydralic Throwout Bearing Install
heres a pic of T1's integra a while back
Old Jul 25, 2010 | 05:30 PM
ALL IMPORT's Avatar
can u use that with an exedy? if not why exactly
Old Jul 25, 2010 | 05:46 PM
sheepey's Avatar
I use it with a CC and works fine.
Old Jul 25, 2010 | 05:55 PM
sanman000719's Avatar
advantages and how does it work
Old Jul 25, 2010 | 06:14 PM
ALL IMPORT's Avatar
did a little research, seems if your not using a tilton clutch u need to use release bearing # 61-770. made for 8.5 tilton or 4.5 - 7.25 NON tilton setup.
went in the garage & checked the specs on my exedy. the forks need a release bearing with at least 2- 2.5 in contact diameter.
here is what i found.
# 61-770 specs are as followed. contact diameter is 2.05 might be small but i think that is the inside edge so it goes out to about 2.5.
only thing i am not sure about is the height. could be a little short. but that is an easy fix with a spacer. i know it wont be to tall because the factory bearing is smaller than the tilton. & i accounted for the fork.
as for the release bearings that are for the tilton. the contact diameter is 1.5- 1.75 so the tilton forks are very close compared to other manufactures.
correct me if im wrong but thats what i came up with doing a quick little research.
page #43
http://www.tiltonracing.com/pdfs/driveline07.pdf
Old Jul 27, 2010 | 07:10 AM
Mr. Em1's Avatar
anyone else?
Old Jul 27, 2010 | 04:58 PM
ALL IMPORT's Avatar
im curious myself if my theory is correct. some of u "smart" guys need to chime in, lol
Old Jul 27, 2010 | 07:25 PM
paulzy's Avatar
which one do you run sheepey?
Old Jul 28, 2010 | 04:55 AM
turbotypeR@SPEC's Avatar
25 Year Member
FWIW, Spec twins have a 1.550" ID center hole in the diaphram and the Tilton bearing works fine with it.
Old Aug 1, 2010 | 12:04 AM
DSRxCandyh2bEG's Avatar
anyone done the tilton bearing with a clutchmasters twin disc?
Old Aug 3, 2010 | 06:53 PM
I.C.C.'s Avatar
Can the tilton release bearing be used with a stock clutch master, or do you HAVE to use the tilton unit?
Old Aug 3, 2010 | 11:53 PM
Zer0_SpeedWorks's Avatar
x2
also im using exedy twinplate...
what part number/kit should I use?
Old Aug 4, 2010 | 03:25 AM
ALL IMPORT's Avatar
^^^ did u read my post above, u can click the link.
Old Aug 4, 2010 | 04:23 AM
opps sorry was not paying much attention,but i downloaded the catalog...
Old Aug 5, 2010 | 09:01 AM
I.C.C.'s Avatar
OK, So I still have not been able to find out whether or not I can use the tilton bearing with a stock clutch master... All I can see is they RECCOMEND using a 3/4 master cyl.
Anyone???
Old Aug 5, 2010 | 09:29 AM
ReDemoN's Avatar
DixielandImports Please
Also can this be used with a regular clutch or just a twin disc
Old Aug 10, 2010 | 08:07 PM
ricin4ever's Avatar
ill be runing this with a stock clutch master cylinder should have it up and working tomarrow . my line had a leak in it i think im leaking fluid some where in my trans **** is a pain in my ***
Old Aug 11, 2010 | 03:24 AM
ALL IMPORT's Avatar
let us know how it works & pics
Old Aug 11, 2010 | 06:53 AM
QUICK8CIVIC's Avatar
Post up your result with the stock master cylinder on the Tilton if it suffices.
Old Aug 11, 2010 | 08:11 AM
tuhboek's Avatar
X2
Old Aug 11, 2010 | 09:49 AM
aboveperformance's Avatar
We tried this last week to avoid pulling the tilton 3/4 master out of another car, the stock master did not flow enough volume to build any pedal pressure. This is why they supply the master cyl with the tilton kit.
Old Aug 12, 2010 | 04:42 AM
the tilton throwout assy needs more volume to move thus Tilton required the 3/4 master assy..OMNI does sell a 3/4 master cylinder kit if Tilton master assy is pricey for the TS.
Old Sep 5, 2010 | 02:56 PM
dai-18t's Avatar
page #43
I think you will find the 61-770 is not the correct part for the HRB on a b-series. The inner diametre is too small and would not slip over the nose in thebell housing whics is 35mm compared to the 61-770 32.
Regards Alex from Oz
Old Sep 5, 2010 | 03:00 PM
dai-18t's Avatar
Sorry forgot to add that you can use the 62-002(52mm) raiused face bearing insted of the supplied 62-008(38mm).
