Resistor Box & Injector Clips question
Ok well, I have right now some 550cc peak & Hold Injectors that I am installing on my Turbo'd teg. Well, I know that I need the resistor box and with these I needed the first gen injector clips also. So I have all of the clips and a resistor box and all I need to know is how to hook it up. I know obviouslly the 4 wires that are coming out of the resistor box go to each injector, but what wire on the clip does it go to? Basically could somebody let me know how to wire in my resistor box. I already know how to replace the clips (just cut the wires to the old clips and replace them with the new clips) but again, I need to know how to wire in that resistor box. Thanks
Later,
Sean C.
[Modified by 20lb.teg, 6:26 PM 9/16/2002]
Later,
Sean C.
Ok, well I wired everything up and it is ididling like complete and utter crap!!! At first I thought it was because of the extra fuel, but then I realized that my Hondata is set for the 550's and then also it was missing and everything at idle!!! So let me just go over this with everybody and hopefully they can help me out. The actual controller wire to the Injector (tells it to open and for how long) still remains untouched. But the power wire (on 94+ tegs it's a yellow/black wire) ALL 4 get wired into the 1 power wire going into the ECU and then in the place of them the wire coming out of the resistor box get wired into place... Don't know if that made sense but I'll work on a pic and post it in a second. Please help me out as I am throwing a code 16 which is for injectors. Thanks
Later,
Sean C.
Later,
Sean C.
Ok, here is the diagram of exactlly how my injectors are wired. Let me know if this is right because again I am throwing a error code 16 and that is for Injectors on a OBD1 vehicle.
The only thing else it might be is that my hondata is set for a GM 3 bar map sensor and I am still running the 1 bar Honda Map sensor. Now I know it would make it fall on it's face like it is doing, but why would it throw the error code 16...
I don't know, some body please help. Thanks.
Later,
Sean C.
I don't know, some body please help. Thanks. Later,
Sean C.
OT: but which diagram should I use to follow for my 96 GSR? The Civic SI one of the hold and peak one?
Oops I using the stock DSM 450's and resistor box
[Modified by xdsmguy, 3:02 PM 9/20/2002]
Good Point, no I didn't check the resistance(I'll check that tonight...), but is it wired right? DO all 4 power wires really go to that one wire going into the resistor box? Oh well, I guess it has some sort of distribution block inside, I opened it up and all I saw was a white ceramic block (probablly for heat dissapation purposes) and the wires going into it, but I will try it.
