JDM H22A parts suggestions?
ok so l got a jdm h22a didnt come with im or tb,injectors,clutch and flywheel so lm pretty sure what clutch and flywheel ill get but please give me some suggestions on other parts for my build. im going to be building this before l swap it so l want good parts that will best perform and work out with a decent price thanks
The Auto Tensioners on the H22s are notorious for failing, and you never know when it might take dump on you which will cause catastrophic engine failure.
Good Luck!
Good Luck!
u can message "randy@bisimoto.com" and ask if u can work out a bundle deal and u wont be disappointed in the performance aspects of there parts im sure but budget wise i like the venom i/m or elderbrock im and u can get a cheap used t/b cheap and get it bored also for fuel rail/injectors its all about personal preference but dont get golden eagle there a pos
http://performance.importrp.com/manu.../i-291139.aspx
was gonna use this for tensioner conversion unless someone knows a better one cant find a h23one
yea thats what l thought. thats y l wrote down that page to order. so obviously blacktrax makes good im's and rosko too but heard rosko's u cant modify later down the line after u make mods. now l see roskos has the entire setup im,tb,injectors,rail does anyone else offer the complete setup? id like to get this all together so they all match up and work well
with a stock manifold you dont have to worry about buying a 150 dollar fuel rail set up, aftermarket or rdx injectors (use different injector connectors than the h22 iirc) etc.
575 for just the manifold is a lot. you still dont have a tb or injectors. Rosko does not provide the injectors with the manifold.
for 425 you coudl have the black trax manifold, tb ported by max bore etc. for another 50 bucks you have 345 cc injectors.
yea probally gonna check junkyards this week now any h22 im will fit correct? or is the jdm motor a dif bolt up? and check this out not sure about this http://dh-racing.com/hseries.shtml bottom page 76 to 77mm tb with a 70mm reducer on stock motor doesnt sound right
BoostdRex
Aug 28, 2007 02:41 PM
Monkey Fing a Coconut
Apr 21, 2004 01:57 PM
