95 Accord Antenna and Coolant Fan problems
Old Jul 24, 2010 | 11:29 AM
amymedders's Avatar
Icon2 95 Accord Antenna and Coolant Fan problems
Hi All, Getting my 95 accord ready to sell and the power antenna broke off. I am just going to put a regular cheapo one on instead of the power one. I am a pretty smart person so can someone tell me where in the trunk would I be looking to attach the wire once I have mounted it to the the outside?
Also, the fan at the front of the car keeps running after the car is turned off. It runs until the battery is dead. I took out a fuse thing to stop it temporarily, but need to find out the problem. The guy at the auto parts store told me that it is a coolant switch or sensor. Is it too much detail someone to tell me where these are located and what I will be checking for to determine what the problem is?
Thanks!
Old Jul 24, 2010 | 12:28 PM
sgraham01's Avatar
Default Re: 95 Accord Antenna and Coolant Fan problems
there are two fans. determine which one is staying on. it's most likely the fan relay that's sticking. pull the fan relay out and replace it with another one that's already in your fuse box. if it stops running with the other relay installed, then your original one was stuck closed. My 94 did this.
when you attach the fixed antenna to the body, you should just be able to plug in the antenna cable to the new antenna. The original one should plug into the new antenna, but if not, there are adapters out there. The place where you buy the antenna should have them.
myheadhertz
Jun 5, 2018 11:16 AM
Josap_CD5
Mar 2, 2016 12:58 PM
mr.mightyone
Feb 24, 2015 08:05 PM
250savage
Dec 22, 2006 03:15 AM
