Shuriken Batteries
Old Jul 24, 2010 | 10:54 AM
SPOOLINmatt's Avatar
Default Shuriken Batteries
Anyone used Shuriken batteries before in car/race car?
They have a 7.5x6.5x3 12v 850 cranking amps battery and they seem to be priced really well.
Im looking at the SK-BT20
http://cgi.ebay.com/ebaymotors/ws/eB...tchlink:top:en
Old Jul 24, 2010 | 11:50 AM
sanman000719's Avatar
Default Re: Shuriken Batteries
im using that same battery in my little EF now. i went from a full sized in the rear to the little shurikan under the hood, and had my fastest time with it so far
Old Jul 24, 2010 | 11:59 AM
boosted2.4's Avatar
i just ordered one but hasn't got here yet so i'm not much help lol
Old Jul 24, 2010 | 12:00 PM
lithium is the way to go with power master though
Old Jul 24, 2010 | 01:01 PM
90blackcrx's Avatar
Its probably because Ninjas promote them.
Old Jul 24, 2010 | 01:45 PM
xenocron's Avatar
Been using one in my EF K-series for two years now. Does the trick nicely!
Old Jul 24, 2010 | 02:32 PM
c5R's Avatar
c5R
ive got one in my car it works great
Old Jul 24, 2010 | 02:35 PM
bonesawvw's Avatar
ninja!
Old Jul 24, 2010 | 03:04 PM
13173's Avatar
I asked this same question awhile back in a thread that was already started about batteries. Didnt get an answer, that I can remember.
Old Jul 31, 2010 | 06:04 PM
portenio78's Avatar
What do yo do about running terminals...just make some adapters?
Old Jul 31, 2010 | 06:24 PM
ring terminals
Old Jul 31, 2010 | 10:28 PM
PRO1's Avatar
[QUOTE=SPOOLINmatt;43114823]Anyone used Shuriken batteries before in car/race car?
Hey spoolin i wonder if that battery would fit in the odyssey bracket?
Looks pretty close
http://cgi.ebay.com/ebaymotors/Odyss...Q5fAccessories
Old Jul 31, 2010 | 11:31 PM
naylor16's Avatar
Got 1 in the S2000, it works great.
Old Aug 1, 2010 | 02:24 AM
Kyle R's Avatar
Glad to hear positive things about this battery. I may end up using one
Old Aug 1, 2010 | 06:20 AM
the pc680 is a little smaller than the shuriken so it might not fit in the pc680 bracket....are you talking about the one from password? maybe they make it slightly larger than the battery ?
You could get this and cut it and space it to make it fit the shuriken.
Old Aug 1, 2010 | 07:30 AM
13173's Avatar
So you guys think this battery would hold up to daily use with a K swapped EG?
I have used a lawnmower battery that never once gave me problems in a different setup. My battery has started leaking acid and it is eating up my battery hold-down. I need to get something different because it continues to do it.
Old Aug 1, 2010 | 07:43 AM
boostedeg302's Avatar
I dont see why it wouldt work. I been searching around for a cheap light battery and it looks like I may be using this one! Thanks for the idea
Old Aug 1, 2010 | 12:08 PM
PRO1's Avatar
Yeah thats the one im talking about, All though you mit be right cut it in half to space it so it fits i think its slighty long battery but same thickness? i may be wrong
Old Jun 20, 2011 | 07:22 AM
q16racer's Avatar
thanks for this thread. Just ordered one. 61.90 with free shipping.
Old Jun 20, 2011 | 08:55 AM
TurboSpoolinInside's Avatar
Edit, nvm.
Old Jun 20, 2011 | 10:27 AM
b18vtecboi's Avatar
Do you need to do anything special with these batteries when you run them? Like trickle charge them while the car sits? Or do they just run like a stock battery?
Old Jun 20, 2011 | 02:42 PM
xenocron's Avatar
Like a normal battery...
Any battery that is going to sit in a non running car for a while should be trickled or disconnected or both.
Old Jun 20, 2011 | 03:53 PM
b18vtecboi's Avatar
Cool thanks
Old Jun 21, 2011 | 12:22 AM
V-SPEC 1's Avatar
You can buy the SAE terminals just like the OEM ones separately. Spoolin, to answer your question, Yes this battery rock It only takes me maybe 1 second or less to start a turbo hatch.
Old Jun 21, 2011 | 12:36 AM
V-SPEC 1's Avatar
[quote=PRO1;43183290]
Looks pretty close
http://cgi.ebay.com/ebaymotors/Odyssey-PC680MJ-Battery-Heavy-duty-Hold-Down-Bracket-_W0QQcmdZViewItemQQhashZitem335f1697baQQitemZ22063 8648250QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
Yes it will fit. I have 2 of those battery tray from Odessey and the Shuriken bt20 will fit in there. It's pretty much the same size battery. I have 2 PC 680 Odessey and 1 Shuriken bought at the same time. The reason why I bought 3 brand new battery? Here's what happened: Other shop that was working on this car before I got it, wired the fuel pump straight to the fuse box and the pump was draining the battery bone dry. I would leave the car for maybe 2-3 days w/o starting it and by the time I wanted to start the car, the battery is dead, Dead where you can't even charge it anymore. The cranking amp were so low that putting it on a charger, and the battery just don't want to get charge. I went through 3 brand new batteries before I found out why a brand new battery would become dead in 2-3 days.
So make sure to either disconnect your possitive cable off your battery, or put a cutoff switch. Do this specially if you have the fuel pump wired directly to the fuse box. It may not be the case if your pump is wired like stock. I hope this help some of you guys. By the way, I bought my Shuriken battery from Sonicelectronix.com for $69.99 and they offer 3 year replacement warranty for like $7.00 and I jump on that. Now, the battery that I bought from them I returned it and they gave me a brand new one.
