DART RACE MOTOR
Old Jul 24, 2010 | 10:32 AM
slick1851's Avatar
Default DART RACE MOTOR
DART MOTOR!
84.50mm bore
LS crankshaft*
JE pistons 9.3:1 compression,upgraded wrist pins and piston rings
Eagle H-beam rods
Moroso 5.5 quart deep sump oil pan with pickup
Type R oil pump
Cometic extreme duty head gasket*
ARP head studs
Golden Eagle head dowels
B16 head PORTED
3angle valve job, ported head
Stainless Crower 1mm oversized intake valves, .5mm oversized exhaust valves
Crower stage 2 turbo cams
Crower duel vavle springs with titanium retainers
Crower adjustable cam gears
TODA timing belt
CTR crank pulley
King Motorsports extended intake manifold studs
Stainless ARP exhaust manifold studs
Edelbrock Victor X intake manifold with Edelbrock throttlebody
stock fuel rail
B&M fuel pressure regulator
RC 750cc saturated fuel injectors
4500$ for the long block, 3500$ if it's a sort block, 1600$for the head complete with cams etc. 500$ for manifold with jg throttle body.
Turbo
630 347 4107
The block is solid deck design, and is good for 1000hp
strongest block on the market don't mess with sleeved stuff
slick1851
Jul 24, 2010 03:05 PM
slick1851
Jul 8, 2010 08:27 AM
slick1851
Jul 6, 2010 06:43 PM
slick1851
Jul 6, 2010 01:33 PM
slick1851
May 7, 2010 09:45 AM
