Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Manual Steering rack question(tried searching)
Old Jul 24, 2010 | 09:35 AM
blackGSRcoupe94's Avatar
Default Manual Steering rack question(tried searching)
my 94 EX comes with factory power steering, well it hasnt been hooked up in five years, and is starting to make a creeking noise, i have a brand new manual rack. i have heard that the subframes are different between an power and non power rack, can anyone tell me if this is a simple "swap" out or do i need to change the subframe. thanks in advance.
Old Jul 24, 2010 | 11:09 AM
Jaker's Avatar
Default Re: Manual Steering rack question(tried searching)
You should be able to bolt the rack in on the driver's side, and with a spacer or thicker bushing on the passenger side, it'll fit no problem. Also, I'm not 100% sure on this, but you might need a different universal joint where the steering rack attaches to the column. I think the PS pinion has a larger diameter spline than the manual one.
Old Jul 24, 2010 | 12:00 PM
powerneedy's Avatar
i know on the teg they switch out without different sub frames... but the knuckle is different like jaker said.
Old Jul 25, 2010 | 05:01 AM
Stinkycheezmonky's Avatar
Suspetise...
I had the universal joint issue Jaker described when I switched to a manual rack.
Old Jul 25, 2010 | 09:27 AM
so do i have to get a joint from a non power steering column then? or modify the existing power steering joint?
Old Jul 25, 2010 | 10:59 AM
JW racing's Avatar
Yep,Manual rack needs a manual universal joint,the spline size on the PS rack is larger.
I ran PS for years with my K swap but recently swapped it for the manual rack to shave weight.I too had to swap the uni-joint and add some rubber to the passenger mount bracket.
You dont need to switch the column at all.
Old Jul 25, 2010 | 11:11 AM
itrSteez's Avatar
Erik95LS took a different approach, it's cheap, you can keep your rack and the car drives awesome. I plan on doing it eventually.
http://www.itrca.com/forums/viewtopic.php?f=3&t=12044
Old Jul 25, 2010 | 02:26 PM
Arsenal's Avatar
Yes. It will bolt in fine. Search my username. I made a how-to thread on how to do the swap. Get a couple questions a month still about it. (Did the swap about 4 years ago)
Old Jul 25, 2010 | 06:16 PM
Suspetise...
This doesn't help with his existing PS rack seemingly going bad.
Old Jul 25, 2010 | 07:53 PM
sc rydah's Avatar
Ever since my ps belt broke my accord years ago, and I had to ride around a while without one, I found I loved the feeling of manual steering. The feedback, the extra control. With a lighter rack, It's definitely worth it.
gotenz90640
Mar 19, 2016 03:57 PM
DohcVtec77
Mar 19, 2016 03:34 PM
NOman0608
Jan 25, 2009 07:17 AM
TurboEK9Coupe
Sep 28, 2008 04:29 PM
aeolus
May 11, 2003 11:03 AM
