sway/exhaust ???
ok so i put on an aftermarket catback a few years ago and recently i upgraded my suspension in the rear and the front now my aftermarket exhaust rattles against the sway bar but im thinking about putting a stock muffler back on and dont know if it will clear the sway bar i have a 18 mm ek4 sway bar in the back blox lca's and 99 si endlinks and an ASR subframe brace. if any one has a stock exhaust and a sway bar in the back let me know if it clears the sway bar so i know if its even worh going back to the stock muffler current one is and egay axel back one
mine only rattles a little and its mostly while im at a red light if im driving its not there ive tried moving the sway bar away from the exhaust but no better cant really adjust it much.
just happened to me too, i used double sided tape and some roll bar padding as a temp fix and it works, although i figured it would have melted or something by now. in my case cutting the sway bracket a little might fix it.
ekhatchey
May 17, 2010 03:09 PM
naptownrex
Jan 7, 2007 04:18 PM
synergy10
Aug 17, 2005 08:46 AM
