DEL SOL GARAGE SALE OF PARTS LOTS!!!!!!!!!!
I need to clear some space so im putting my del sol parts up.. Everything has pictures. I have more pics to come.. so if you dont see it pm me and ill let you know if i got it..
Del sol SI 5 speed pedal assembly
Ebrake and gauge cluster dash piece
Driver side sunvisor and lower steering column cover
red, white and black del sol gas lids
cruise motor and cable, D series starter, oem horn
Passenger side seat belt, srs unit ecu and im blank on third part
del sol oem front brake lines
D series throttle cable
gas release cable
2 oem horns
passenger door hinges
tarmac roof rails
under dash fuse box
passenger side inner door latch
2 steering columns with tilt
horn, upper steering column cover, hood release
rear window molding
passenger side mini window, 2 driver side mini windows
sunvisor set
driver side and passenger side mini window moldings
2 del sol gauge cluster harnesses
del sol S airbag harness
del sol SI airbag harness
del sol rear sails and 3rd upper brake light
del sol brake booster
del sol brake booster and master cylinder
3 climate control harnesses.
del sol oem jack
trunk hinges black and white
clutch master cylinder and reservoir
white door hinges and horn
interior ac harnesses
del sol trunk molding
driver and passenger lower door moldings
tarmac roof panel liner
driver side and passenger side window switches, 2 window control relays, roof warning relays
del sol hood cable
driver side headlight harness
Eg/del sol heaters,evaporators
del sol windows
del sol misc pieces
2 del sol rear windows
del sol oem sideskirts
del sol sideskirts #2
front and rear bumper foam
Please bump if you view.. thanks more pics coming
gas release cable
2 oem horns
tarmac roof rails
under dash fuse box
rear window molding
sunvisor set
del sol oem jack
del sol hood cable
del sol windows
del sol misc pieces
