JDM ZC NO SPARK HELP HELP.
Old Jul 23, 2010 | 07:45 PM
Shaw14's Avatar
Default JDM ZC NO SPARK HELP HELP.
I have a 88 hf crx with a swapped jdm zc dohc motor and ive put plugs wires dizzy and dist cap now I dont know what dizzy I should have really but I imagine the common is 88 91 single cam one but for some reason still no spark just want the car to start I have fuel no spark I wont be back on here tonight but if someone can throw me a text or something it would be helpful 253 929 4262.
Old Jul 23, 2010 | 11:31 PM
kamui427's Avatar
Default Re: JDM ZC NO SPARK HELP HELP.
when you take off your dizzy there is a stamped number/letters on the side match that up for the replacement distributor.
Old Jul 24, 2010 | 05:15 AM
Sikocivic's Avatar
You can use the dizzy from the 88-89 Integra motor for a DOHC ZC. The one from a SOHC won't bolt on that motor. You will need to change the dizzy plug but it's easy. Just repin it, all the wire colors are the same.
Look in the FAQ for more info on this.
89crxherndon
Feb 21, 2010 04:30 PM
jbrokos307
Aug 20, 2009 02:44 PM
dr@ke
Sep 9, 2006 06:02 AM
MugenFlaredCRX
Jul 15, 2004 03:24 PM
