running jdm itr motor on p73 ecu
Old Sep 16, 2002 | 01:48 AM
HybridGSR1's Avatar
Default running jdm itr motor on p73 ecu
im just wondering if any you know if this works.... a 96 jdm itr motor runing an obd2 p73 ecu, should i swap out the ecu for a itr one?
Old Sep 16, 2002 | 04:03 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: running jdm itr motor on p73 ecu (HybridGSR1)
Use a rechipped P28.
Old Sep 16, 2002 | 05:16 AM
Trey's Avatar
25 Year Member
I'm not sure what your question means.
A 96 JDM ITR (96 SpecR) uses a OBDII P73 ECU.
The plugs are OBDII, the program is OBDI.
I have a 96 SpecR P73 ecu running my 98 GSR swap in a 96 CX and everthing plugs up and runs fine.
Chipped P28 will need an OBDII to OBDI ecu jumper harness.
Old Sep 16, 2002 | 07:16 AM
Apex i ITR's Avatar
Default Re: running jdm itr motor on p73 ecu (Trey)
Unless the car is already OBDI (Which I assumed).
Kenny88880
Apr 17, 2014 12:03 PM
D-series ninja
Nov 22, 2004 10:06 AM
ELUD THS
Jun 18, 2003 09:13 PM
92TypeR
Oct 28, 2002 12:21 AM
808State
Oct 10, 2001 12:49 PM
