95 ls tranny ?
Yes if the input shaft does not spin freely there is an issue with the transmssion. It could be as simple as the case was not properly installed. Check the snap ring on the countershaft and make sure it is seated correctly.
was it the original transmission off the car? if not then it could be trashed. send me a pm. and yes it would also be the c clip if it was not peoperly seated
