honda del sol idler air controller???? HELP
Old Jul 23, 2010 | 02:04 PM
shady3260's Avatar
Default honda del sol idler air controller???? HELP
Got a 95 del sol just rebuild engine an installed it and i never had an idle problem before the engine blew but i rebuit it and put the engine back in and now the idle on it is crazy. It idles from 1000 to 3000 up and down up and down when it is parkd idling. If im driving it it runs fine and all that but when i pull to a red light it is really embarssin when the car is idling up and down.. Ive messed around with the idle cable wit no luck someone says it can be ur idler air control sensor....Does anyone know how to tell if this is bad if i unplug the sensor the car only stays idled at 1200 and goes up and down to about 1500 but when u are driving it with it unplugd it wants to stall out if you are driving the car in lower gears and its running about 1500 rpms does anyone have any ideas i need to get this fixed cuz ims elling the car soon
Old Jul 23, 2010 | 02:10 PM
Former User's Avatar
Default Re: honda del sol idler air controller???? HELP
Check for vacuum leaks.
Make sure the throttle cable has about 1/2" slack.
Clean and adjust the FITV.
Clean the IACV.
Any CEL codes?
Old Jul 23, 2010 | 09:33 PM
shady3260's Avatar
checked vacuum leaks and cant find any and i will adjust the throttle cable in morning and what is the FITV and IACV and CEL codes i dont know how to check them or what exactly u are talking about should my car show codes if so how do i do that and what should i clean the FITV and IACV with
Dtucker1994
Dec 30, 2014 11:35 PM
tgordenDELSOL
Oct 12, 2014 11:26 AM
wwbiker832
Jan 13, 2014 09:17 AM
shady3260
Jul 23, 2010 10:50 PM
Schmedley
Sep 13, 2002 11:07 AM
