f/s lots of gsr parts, and 4dr gsr shell
1. 96 or 97 )can't remember) Gsr complete shortblock 90k miles with brand new p30 pistons/ wrist pins and rings. will need new oil pickup gasket & oil pan gasket. - $800 0b0
2. Blox manifold comes with fuel rail and obd-1 gsr injectors, fpi - $160
3. obd1 Gsr dizzy - $150
4. hydro bseries Clutchmaster stg3 clutch/fidanza flywheel - $400/$140,
5. B16 pr-3 obd1 ecu - $150
6. gsr/b16 Kamikaze 2.5in collector header - $100
7. Oem gsr intake manifold - $50
8. 2 b16/gsr valve covers
9. B16 block internals $50
10. Gsr p72 head internals $75
11. bnib aftermarket nippon pistons in 81.50mm, will come with wrist pins and bnib nippon piston rings. piston's are pr-3 casting asking $150 obo
12. used b16 pr-3 piston's and rods all in good shape except for one rod that had a rod knock $obo
13. also have my 94 integra gsr 4dr for sale also, the color is stealth gray ( purple/gray mettalic) with over 250k on the body, the original odometer broke so i can't say how much is on it really, it has a clean title. body needs some tlc, lots of small dings here and there on the doors and one big one on the trunk lid, will need a paintjob, the clearcoat started peeling off. aftermarket parts on the car comes with kyb agx struts with skunkworks coilover sleeves, custom 2.5in exhaust with carsound 2.5in cat convertor, 17inch rims with 80-90% tread on it, type r 24mm front sway bar. the car is being sold as is a rolling chasis, and will need a complete engine swap. ie like axles, ecu, shift linkage, wiring harness. other than that everything else is there besides that. asking $1500 for everything mentioned, $1000 minus strut/coilovers, sway bar and rims. i don't have any spare rims so u must have ur own if your purchasing it. have title on had
for any questions feel free to text or call me 206-214-6325 begin_of_the_skype_highlighting 206-214-6325 end_of_the_skype_highlighting, if i don't pick up leave a message and i'll call back asap. pls no calls past 12am text is fine.
for pics just ask and i will pm it to you
Si2See
May 11, 2007 07:12 PM
