B16 swap in ek sedan
Old Jul 22, 2010 | 02:51 PM
landon2992's Avatar
Default B16 swap in ek sedan
Im about to swap my d16y8 out for a B16A Sir2. Comes with everything ill need to swap it out. This is my first swap to my civic..so will this motor swap just "drop" right in? Comes with hydraulic transmission, Motor, Ecu, clutch/flywheel, axles, half shaft, shift linkage, starter, alternator, distributor, throttle body, Intake manifold, exhaust manifold, fuel rail, injectors, sensors and stock motor mounts.
Old Jul 22, 2010 | 03:29 PM
darkdc2teg's Avatar
Default Re: B16 swap in ek sedan
Some of the posts in my thread may help you out. JDM swaps have a few tricky details that need to be addresed. Im droping in a complete b16b swap. You will prob run into the same snags as me with the b16sir.
Old Jul 25, 2010 | 06:05 PM
landon2992's Avatar
like i said i don't know too much about swaps yet..but will the b16b swap need to have issues resolved too? cause the b16a sir2 motor i wanted was sold out now. so im still looking for something to put in my car.
Old Jul 25, 2010 | 06:43 PM
Sr420Det's Avatar
if its obdII everything will swap right over you just wont have a pressure switch, so if u use your harness ul have an extra plug there. Your exhaust wont fit so you'll have to deal with that and you'll need the cats and o2's if u dont want a cel. If its obdI than itl b alot different cause ur plugs for the dizzy, alt, and injectors wont fit but U can make them work easily enough
Old Jul 26, 2010 | 12:26 PM
landon2992's Avatar
thanks man. I'm def looking for obd2. I'm thinkin about doing the b16b swap so everything should work well. The motors i was looking at come with the wiring and ecu
jdm_ek_noob
Oct 9, 2013 03:53 PM
90civSi
Jul 14, 2005 10:35 AM
Mr.c
Nov 7, 2003 03:21 PM
