Megan Racing EZ Street Series Coilovers (Civic, Accord, Integra, Prelude, S2000)
MSRP $799.00
Hondatech special $660.00 SHIPPED or $620.00 PICKUP.
CALL OR PM me.
Megan Racing EZ Street Coilover Damper Kits - the latest offering from Megan Racing targeted for those who are looking for performance and on a budget. EZ Street Coilovers provide 15 Levels of damping force adjustment, full-height adjustment, and are finished with strengthened rubber bushing top mounts. Megan Racing coilovers have springs that are made of SAE-9254 Steel, and are tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating spring durability was highly improved.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Megan Racing EZ Street Coilover Kit is the perfect choice for the budget racers
Features:
- 15 Levels of Adjustable Damper Strength
- Strengthened Rubber Bushing Top Mounts
- Rubber Dust Covers
- Adjustable Ride Height
- Aggressive Spring Rates
- Mono Tube Design
- Aluminum Brackets
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
Application:
MR-CDK-EF-EZ - Civic/CRX/90-93 Integra 10KG/5KG
MR-CDK-HA03-EZ - Accord 03-07/TSX 03-07 10KG/5KG
MR-CDK-HA08-EZ - Accord 08+/09+ TSX 10KG/5KG
MR-CDK-HA90-EZ - Accord 90-9712KG/5KG
MR-CDK-HA98-EZ - Accord 98-02/TL/CL 99-03, 12KG/5KG
MR-CDK-HC92-EZ - Civic 92-00/Integra 94-01 10KG/5KG
MR-CDK-HP92-EZ - Prelude 92-01, 10KG/5KG
MR-CDK-ME95-EZ - Eclipse 95-99/ Galant 94-98, 12kg/6kg
MR-CDK-MMX590-EZ - Miata 90-05 MX5, 8kg/6kg
MR-CDK-N30-EZ - R32 SKYLINE/300ZX 90-96 Z32
MR-CDK-S2K-EZ - Honda S2000, 30 x 18 x 9, 10KG/10KG
MR-CDK-TS86-EZ - TOYOTA SUPRA 86-92, 14kg/8k
CALL OR PM me.
Features:
- Mono Tube Design
- Aluminum Brackets
Application:
I'm about to order these Coilover's on eBay, but I'd rather buy them a more trusted source. (i.e hondatech) Are these still for sale?? If so I will be happy to buy them off you asap..
Thanks
Thanks
Touge Factory
13
May 16, 2011 11:19 AM
jwood122
643
Dec 4, 2008 06:46 AM
