90 DX shut down???
for the past cuople days ill be drivin and my car will just shut down while rollin tried startin it back up by down shifting that didnt work once i got completly stopped car fired right up...yesterday i was stop waitin on traffic had radio on didnt hear car shut down but i tried startin til batt went dead...after i got a jump and a cuolpe more tries car fired...and suggestions on wats wrong p.m. me or comment post thanks for the help...
you should check your vacuum lines for any leaks or damage on the lines. how long has it been since the car got a tune-up? it could be a basic repair so i start with the basic first . a clogged fuel filter maybe.
ok and i guess its been awhile and i was thinkin the fuel pump is goin out some days its fine and some days it has it moments ya kno thanks for the advise tho ill check it out here in a few
car had a problem over heatin so the thermostat is outta ? and as long since i had the car you could never hear the fuel pump click but ill check it out thanks
youll have a better chance of hearing the main relay turn on... or you can loosen the fuel filter line and prime the car to see if theres fuel pressure at the line...
275Performance
Apr 23, 2004 03:34 PM
