rear disk
Old Jul 22, 2010 | 10:57 AM
sevwen7's Avatar
Default rear disk
will the rear disk off of an integra with the flip up lights, i think thats 1st gen, be able to fit on my 91 sedan?
Old Jul 22, 2010 | 04:10 PM
Projekt_Ef9's Avatar
Default Re: rear disk
Idk if they will work but i know that the DA (90-93) Integra ones will work.
Old Jul 22, 2010 | 04:54 PM
sevwen7's Avatar
alright. i was in a hurry and i didnt look around enough to find a da. ill check next time, the wreck yards just down the street
Old Jul 23, 2010 | 11:02 AM
EE2bitsk's Avatar
ya look for any from a 90-01 integra.
also if you were wondering, the integra hatch e-brake cables fit perfect, dunno if the sedans are the same but you could check if you felt the need. lol.
Old Jul 23, 2010 | 11:18 AM
sevwen7's Avatar
the newer integra ones will fit? cause i saw lots of those
Old Jul 23, 2010 | 11:50 AM
BrayzieEF9's Avatar
I got 96 LS integra rear disc on my hatch.you need DA integra hatch/coupe e brake cables.
Old Jul 23, 2010 | 12:01 PM
csingham's Avatar
crazy mad murdock
and shocks
Old Jul 23, 2010 | 12:06 PM
BrayzieEF9's Avatar
Originally Posted by csingham
and shocks
no you don't? dont forget the correct MC,BB, and prop valve
Old Jul 23, 2010 | 12:10 PM
sevwen7's Avatar
is mc master cylinder? and i dont know what bb is. haha im still pretty new
Old Jul 23, 2010 | 12:14 PM
BrayzieEF9's Avatar
this thread will answer all your questions,if it doesn't.It's obvious your not reading then.https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rear-disk-brake-conversion-w-pics-1916212/
MC=Master Cylinder
BB=Brake Booster
Prop valve=Proportioning valve
Old Jul 23, 2010 | 12:59 PM
sevwen7's Avatar
haha alright thanks man
Old Jul 23, 2010 | 01:01 PM
EE2bitsk's Avatar
technically you dont need the brake booster. i just did rear discs on mine and did the prop valve only and it stops perfectly fine. i could see getting the brake booster if you upgrade the front breaks as well.
Old Jul 23, 2010 | 01:14 PM
BrayzieEF9's Avatar
yeah Technically, but you need it to bolt up the DA master cylinder.since the MC ain't gonna bolt up correctly(different flange angle)to your stock booster.Plus your not gonna feel a difference in braking til you get the 15/16 Master cylinder.
Old Jul 23, 2010 | 02:26 PM
EE2bitsk's Avatar
well thats what i meant was the master cylinder and brake booster lol.
but that makes sense, i need to get on that ish for mine ASAP. thanks for the heads up dood.
Old Aug 9, 2010 | 02:58 PM
If you have an 88 you have to change the rear lcas as well.
Old Aug 9, 2010 | 06:36 PM
asianflava's Avatar
I'm pretty sure it won't work. The first gen Teg which shares the same suspension as the 84-87 CRX (3G) had solid beam rear axles. The newer Civics (4G and up) have independent rear suspension.
Old Aug 9, 2010 | 09:49 PM
sevwen7's Avatar
haha yeah i figured that out now. and i found a nice da there so ill pick off that for a while
Old Aug 9, 2010 | 10:09 PM
Fo-Do Fanatic's Avatar
http://www.fourthgenhatch.net/reardiscswap.html Use this write-up. Great info. Tell's you everything you need to do it and every single step down to the tee. I'll be following this tomorrow and I know it'll be easy doing so with this write as a few of my buddies have done it with this write up. GL.
Old Aug 9, 2010 | 10:29 PM
sevwen7's Avatar
oh sweet! this one looks way better than the other one i found. thanks fo-do!
Old Aug 10, 2010 | 08:01 AM
EL Vap133's Avatar
As mentioned earlier, you need the 90-01 Integra rear disc brakes. I would get all the components together and install them all at once because bleeding brakes is not fun.
Old Aug 10, 2010 | 11:30 AM
Im about to do mine today just found an almost complete 91 integra for parts. thanks for that great write up Fo-Do Fanatic that will help out a lot.
Old Aug 10, 2010 | 02:11 PM
That's the write up I'm going to use. fourthgenhatch.com has a lot of really cool/useful links on what to do on some things.
JDM'd OUT
Feb 4, 2008 08:07 AM
civic89si666
Mar 3, 2007 07:33 PM
sick90hatch
May 6, 2004 12:53 AM
