B20 Sleeves are NOT strong
Old Sep 15, 2002 | 11:05 PM
Ri5e's Avatar
Default B20 Sleeves are NOT strong
I pulled off my head tonight to see why it the motor overheated and why it would die out at idle:
Old Sep 15, 2002 | 11:36 PM
ANB Clothing Co's Avatar
Default Re: B20 Sleeves are NOT strong (Broken CRV)
ouch....sorry bout that man, im starting to reconsider my b20 plans....
Old Sep 15, 2002 | 11:39 PM
Kamin's Avatar
no ****.
its still a stock honda sleeve.
they are cracking more and more like that
how much boost were you running
[Modified by KAMiN, 12:39 AM 9/16/2002]
Old Sep 15, 2002 | 11:40 PM
tinkerbell's Avatar
so what did you do to it?
t..
Old Sep 15, 2002 | 11:58 PM
Ri5e's Avatar
Default Re: B20 Sleeves are NOT strong (tinkerbell)
Just 16 PSI cracked it. B20 sleeves are probably the weakest B series sleeves.
I'm going to make some phone calls tommorow for GE Sleeves
Old Sep 15, 2002 | 11:59 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
How unfortunate of you to find out this way , how could I prevent myself from being subjected to this in the future, I am going NA in a b20z with a goal of 210 whp? Any preventive help to create stronger sleeves would be appreciated?
Old Sep 16, 2002 | 01:09 AM
Kamin's Avatar
JUST 16psi?
Old Sep 16, 2002 | 01:49 AM
Maximus's Avatar
Default Re: B20 Sleeves are NOT strong (KAMiN)
How long did the motor last before the sleeves cracked?
Ouch
Old Sep 16, 2002 | 04:27 AM
DevinW's Avatar
i 2nd Kamin's statement..."JUST 16 Psi? "
Old Sep 16, 2002 | 05:16 AM
SuperCivic's Avatar
guess this just goes to show..honda b-series AREN'T like nissan's sr20s.
Old Sep 16, 2002 | 07:26 AM
itzxeo's Avatar
Default Re: B20 Sleeves are NOT strong (SuperCivic)
Silly aluminum blocks. I hate em. Oh well, when you deal with the majority of imports you have to deal with it, either sleeve the b20 for anything over 12-13 psi, or buy a miata Iron block, 21psi, new rods, new 9:1 pistons = love. Good luck with your woes.
Chris
Old Sep 16, 2002 | 08:12 AM
JeffNA's Avatar
Default Re: B20 Sleeves are NOT strong (DevinW)
Ditto
Old Sep 16, 2002 | 08:25 AM
g's integ's Avatar
10lbs is alreadt pushin it but 16!
Old Sep 16, 2002 | 08:30 AM
SiBirdie's Avatar
Default Re: B20 Sleeves are NOT strong (g's hybrid)
umm how can crv sleeves suck? CRV has thicker sleeves then a LS motor. IF your runining at 16psi at stock buttom end, I bet you any honda sleeve wont handle that much power.
Old Sep 16, 2002 | 09:26 AM
eg6madness's Avatar
Default Re: B20 Sleeves are NOT strong (SiBirdie)
JUST 16psi ?
if you throw "JUST 16psi" at any honda block ( whether VTEC ot not ) it WILL Break . most guys know that runnin 12 psi or so is about the max that stock sleeved honda blocks can take .
So next time throw "JUST 10-12 psi" and see what happens
Old Sep 16, 2002 | 04:07 PM
H22EK's Avatar
Default Re: B20 Sleeves are NOT strong (eg6madness)
DAMN 16 psi on a stock bottom end is crazy foo!!You should have "just" ran straight aviation fuel too and then wondered why the f*cker melted down!!!! I think in this case it would be operator error not bunk sleeves!!
16psi(stock)=
16psi(ge sleeves)=
Old Sep 16, 2002 | 04:16 PM
tinkerbell's Avatar
Default Re: B20 Sleeves are NOT strong (H22EK)
to shed some light on tha actual title of this thread, here is an article that was posted in another thread by someone else... (cant remember either!)
it is an article from Automotive Engineering, January 1996 on the B20 sleeve process (pretty technical though...)
http://dwolsten.tripod.com/articles/jan96a.html
HTH provide some facts...
t..
Old Sep 16, 2002 | 05:02 PM
1 2 NV's Avatar
judgin by the pics, looks like u had inconsistent burn. cyl 2 &3 look "clean" but cyl 1 & 4 look dirty. most likely the cause of the cracking was due to detonation, my guess pre detonation. but like already stated 16psi is pushin it anyways.
Old Sep 16, 2002 | 05:21 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: B20 Sleeves are NOT strong (hondaatwsu)
Your a moron.. you ran 16psi on stock internals..?
Edit: I don't know that much about FI.. but i know enough to not mess up like that..
[Modified by Hatchy-Ownzjo0, 9:24 PM 9/16/2002]
Old Sep 16, 2002 | 05:27 PM
tinkerbell's Avatar
Default Re: B20 Sleeves are NOT strong (Hatchy-Ownzjo0)
no - not a moron, just adventurous:
"I'm keeping it non VTEC and gonna try to push HP figures AND torque both at the same time. Maybe try to break some records =P"
on stock sleeves, 239WHP was a good start...
t..
Old Sep 16, 2002 | 08:07 PM
civic disobedience's Avatar
I know its been said already, but DAM 16 psi, how long did it last @ 16? Im about to go to 12 soon on my b16a2 and I am a bit leary... you must have a whole lot of money burn...good luck
Old Sep 16, 2002 | 10:15 PM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: B20 Sleeves are NOT strong (1BARGSR)
Whats up with the 16psi thingy. I have ran 12psi on a bone stock B18b daily and at the track 17psi. It's all about the tuning. You can run 20psi on a stock b18b. I've seen it before. Yong post my video when i pushing like 17psi.
Old Sep 17, 2002 | 12:09 AM
SSBP DC2's Avatar
Default Re: B20 Sleeves are NOT strong (Civicdrgrcr)
brokenCRV...what are you goin to do now?
Old Sep 17, 2002 | 12:39 AM
Default Re: B20 Sleeves are NOT strong (NA builder)
He's doing what I did
Ship block out to Viren to get it sleeved.
Old Sep 17, 2002 | 12:40 PM
miller's Avatar
Default Re: B20 Sleeves are NOT strong (VTEC CX)
golden eagle sleeves
