stock fuel pressure setting
Old Sep 15, 2002 | 10:42 PM
YumVTEC's Avatar
Default stock fuel pressure setting
I guess I shoulda installed my fp gauge, and checked what it was at before I put the FPR on. Heh... I'm posting here 'cause the motor is a b18c5 and i don't know if it's different between honda motors.
i did a search and didn't find anything very useful. Also, i've read that you have to remove the vacuum line off the fpr to accurately test fuel pressure. Is that correct?
I set it at around 31-33 psi today with the vacuum line undone, and at WOT it goes to about 41-42 psi. My motor is stock, with just bolt-ons, but I do have a skunk2 chipped p28.
I bought the fpr and field vtec controller to be ready to adjust stuff at the dyno, whenever i can get the money to go. I would've gone already, except I'd like to get some cam gears before I go, so I can make the most out of my time on the dyno.
I just wanna keep the fuel settings as near to stock as possible, so I don't screw something up. Any advice?
Old Sep 15, 2002 | 11:01 PM
92TypeR's Avatar
FSAE
Default Re: stock fuel pressure setting (YumVTEC)
I believe the ITR fuel pressure is 43psi stock. I may be wrong....
Old Sep 16, 2002 | 12:39 AM
sgT's Avatar
sgT
If the vacuum line is "undone" then your WOT pressure should be the same.
ALWAYS CHECK FUEL PRESSURE WITH THE VACUUM LINE REMOVED.
With that said, stock ITR pressure is 49-54psi
Old Sep 16, 2002 | 09:51 AM
YumVTEC's Avatar
Default Re: stock fuel pressure setting (sgT)
wow, those numbers seem way high. is that what the helms manual says? damn, i need to get one of those.
Old Sep 16, 2002 | 09:58 AM
therealnapster's Avatar
New User
Pretty sure its 43 psi. if you dont believe us why dont you just throw your stock regulator back on and check your guage your self to be sure...it takes like 5 min...
Old Sep 17, 2002 | 07:04 AM
YumVTEC's Avatar
Default Re: stock fuel pressure setting (dothemath)
shitty for me I bought a b&m and had to hack my stock regulator up. Can I use any stock Honda FPR to test it? Not a bad idea!
Old Sep 17, 2002 | 07:26 AM
JPP's Avatar
JPP
The stock pressure with vaccum hose off is 49-54 PSI as mention by SGT (trust me he knows his stuff) and in the Helm manual.
My stock pressure was 52 PSI.
If you buy any stock Honda regulator, it will give the pressure at which it is set at and not necessarily the correct one (Honda does not use the same regulator in all it's model)
Old Sep 18, 2002 | 08:02 AM
YumVTEC's Avatar
Default Re: stock fuel pressure setting (JPP)
well damn, why does my car idle so much better when i first start it with my FP at like 39psi ?
The idle hates when you mess with fuel settings. My SFC-VTEC is set to 0's all across the board, so if my FP is set to 47-50psi then my idle should be normal. If it's not, could it be my chipped p28 causing the problem?
EJ1B18c
Jan 15, 2011 11:08 AM
Teamdiesel
11
Nov 11, 2007 05:39 PM
Mr.EM1
Jan 6, 2005 11:17 AM
TrboInteg
Oct 26, 2003 06:57 PM
01itr518
Jan 8, 2002 12:17 PM
