h.i.d. 8k problem
Old Jul 21, 2010 | 08:48 PM
emgjsdk1's Avatar
Default h.i.d. 8k problem
i picked up a used set of hids off a friend today, they worked fine in his car before taking them out, they worked fine in my car after putting them in, but after driving 15 minutes only the driver side has a blue/white tint and the passenger side looks like a halogen bulb.
my car is 98 civic ex, could i be looking at wiring problems in the car?
Old Jul 21, 2010 | 08:49 PM
92lxsleeper's Avatar
Default Re: h.i.d. 8k problem
do they have a halogen high beam?
you may have the 2 wires backwards on the passenger, or drivers side. so you would have one xenon low beam, and one halogen high beam on.
Old Jul 21, 2010 | 08:58 PM
emgjsdk1's Avatar
i was thinking the same thing but thought i would blow the passenger side fuse if the wires were mixed up ( the car has new pig tails for the headlights due to the previous owner clipping the oem ones for god knows what reason...)
they are a single beam kit, low beams are halogen and highs are hid.
Old Jul 21, 2010 | 08:59 PM
D16SiHatch's Avatar
you contradicted yourself. if its a single beam kit then you only have the low beam. if its dual then you have an hid low and halogen high, not the other way around..
Old Jul 21, 2010 | 09:03 PM
emgjsdk1's Avatar
either way i am still having a problem with them
Old Jul 21, 2010 | 09:07 PM
D16SiHatch's Avatar
well it's hard to figure the problem out if you don't know what you have.. if its a hid/halogen kit then it's possible you have the wires reversed on one side. if that's not the case then its possible the xenon bulb was damaged somehow in the switch. from what i've seen they tend to turn a halogen like peach color before they go out for good. how long it will last like that is anyones guess though.
Old Jul 21, 2010 | 09:12 PM
emgjsdk1's Avatar
ok before i put the hids in, there were standard halogen bulbs in. i didnt touch any wiring, just plugged them in. Would i experience any problems if the wiring was wrong with halogens? Also i was very careful not to touch the bulb or anything too.
#Hatch
Lighting
May 3, 2012 07:42 PM
emgjsdk1
Jul 22, 2010 08:05 AM
Weak!EG
Lighting
Mar 4, 2009 08:59 AM
J.nguyen
Honda S2000
Aug 13, 2007 11:44 PM
Night Kid
Sep 12, 2001 08:42 PM
