oil leak between head and block
Old Jul 21, 2010 | 06:57 PM
oldskooldan's Avatar
Default oil leak between head and block
sup guys so i just recently finished putting my motor together.
and thereis a leak in the front corner near the trans.
the head is tapped. im using a ge headgssket.
did i put it wrong? or what could it be?
Old Jul 21, 2010 | 06:59 PM
HPTautosport's Avatar
Default Re: oil leak between head and block
Did you use the dowel pins to align the gasket? 100% positive you put it on right side up? OEM or ARP head studs?
Old Jul 21, 2010 | 07:07 PM
yes i did put the dowel pins
im using golden eagle hs
Old Jul 21, 2010 | 11:02 PM
bump
Old Jul 22, 2010 | 06:39 AM
lsef's Avatar
Did you seal the tap?it will leak though the threads if you dont put honda bond to seal it up after you put the plug in.
Sr420Det
Apr 16, 2011 02:55 PM
scspeed
Mar 28, 2010 06:50 AM
scspeed
Apr 18, 2009 01:54 PM
sickerhatch
Mar 1, 2005 03:19 PM
hybridtech
Jun 14, 2004 01:51 PM
