D15B2 no spark - minimum RPM to start?
Old Jul 21, 2010 | 06:21 PM
FSRslug's Avatar
Default D15B2 no spark - minimum RPM to start?
Long story short, I had a working D15B2 with MPFI swap and it worked fine. Swapped it for a D16Y8/Z6 combo. It worked great until a bearing spun. I had another D15B2 and put it in, but it wont start. I have no spark. The engine is heavily used and I don't know its history. It turns over very slowly. The battery is less than a year old and has a full charge. Tried jumping with another battery and still, slow cranking. It is harder to turn at the crank pulley with a breaker bar than the other motor were. I have given in that this motor is crap and probably has internal damage, rust, sludge adding too much friction for it to turn over smooth. I swapped starters to make sure that was not the issue. Plug wires ohm out OK, plugs are new and gapped correctly. I still don't understand why I have no spark.
Followed the FSM for checking the dizzy, wiring, and ECU. Everything seemed OK, but I swapped out a known good dizzy just to be sure. Still no spark.
I am wondering if there is a minimum RPM before you will generate spark. Anyone have thoughts on that?
95sirek4
Sep 2, 2011 07:35 PM
shock.top.pat!
Honda Motorcycles
Jun 21, 2011 08:09 PM
teal91
Dec 5, 2008 04:45 PM
FunStuff
Aug 1, 2007 03:15 AM
civic92si
Mar 29, 2007 08:28 PM
