just got firestone alignment but new problems occur?
Old Jul 21, 2010 | 05:46 PM
TeamEK's Avatar
Default just got firestone alignment but new problems occur?
Before i was having only front tire wear, then i got new tie rods and it fix my tire wear, Then my car wasnt drivein straight, so i went to firestone to adjust my toe. NOW after two days of driving i am starting to get camber wear!!! Should i go complain to them or was this met to be?
Old Jul 21, 2010 | 05:59 PM
LSBoostedEk's Avatar
Default Re: just got firestone alignment but new problems occur?
once a tire starts to wear funny there is no way of stopping it. it will continue to wear that way until you get a new set.....that is if you don't have any other problems
Old Jul 21, 2010 | 06:12 PM
Jimmy's Avatar
Global Moderator
Could you tell us a little more about your suspension setup?
Do you have camber kits? What are your settings?
Can you get a print-out?
Old Jul 22, 2010 | 05:36 PM
TeamEK's Avatar
everything stock but i have 15 rims with yoks tires, and sportline eibach springs. But yeh i had them on before the alignement and my tires were okay but not the toe then went to firestone and started to get camber wear.
umm gonna try and put my specs on here later.
Old Jul 22, 2010 | 06:48 PM
shogee's Avatar
so did you install any adjustable upper control arms or anything. if all they did was adjust toe and go and you have no way of adjusting camber because from the factory there is no way of adjusting camber.
Old Jul 22, 2010 | 08:11 PM
babyboy53190's Avatar
I took my car to get the firestone alignment and i drove more than one month with a loose tierod nut that adjusts toe. Ill just leave it at that.
Old Jul 22, 2010 | 09:53 PM
98civdx's Avatar
Master Detailer
Do you have a print out? If so, what is the camber at?
Understeer
Suspension & Brakes
Apr 4, 2006 12:13 PM
kcem1
Suspension & Brakes
Dec 15, 2005 01:48 PM
8Grand
Jun 30, 2004 12:02 PM
blurrrcivic94
May 5, 2004 06:59 AM
Civic-Stiz
Jun 21, 2002 06:15 AM
