What a sad day. Cracked B20 Sleeves
Old Sep 15, 2002 | 10:10 PM
Ri5e's Avatar
Default What a sad day. Cracked B20 Sleeves
Running 16 PSI for just 5 seconds, the car shut off. Car kept overheating. So I removed the head...and found out that B20 sleeves are NOT strong at all even with proper tuning. The JE's are in perfect condition. Goodbye all, I will one day return back to this forum.
Old Sep 15, 2002 | 10:14 PM
austrian type-R's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (CRV Monster)
damn, that sucks. Sorry dude.
Old Sep 15, 2002 | 10:21 PM
blufke's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (austrian type-R)
that was with forged pistons and rods? block guard?
Old Sep 15, 2002 | 10:24 PM
turbopanda's Avatar
Sorry to hear about that. Maybe that wouldn't have happened if you had a blockguard.. my teg is in the shop right now getting my damaged B18C out, and a B20B bottom installed (with my B18C head). I have lowered compression, a blockguard, running stock pistons/rods - after seeing those pics, I don't think i'll push anything higher than 10psi without a set of pistons/rods and some strong sleeves..
(btw, if there's anything else you want to warn me about, please tell me!)
Old Sep 15, 2002 | 10:32 PM
Ri5e's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (turbopanda)
There is no way a blockguard could've prevented the sleeves from cracking. Yes, JE pistons and Eagle rods. They are in perfect shape. The sleeves aren't
What are some good places to get my B18A sleeved? JG? GE?
Old Sep 15, 2002 | 10:38 PM
BrokenVtec's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (Broken CRV)
i had a b20vtec that lasted me 1 WEEK in an all motor set up! those have to be the weakest sleeves ever made! sorry to hear it man but i know how it feels. i was running JE 12.5:1 with crower rods and i didnt even get 1000 miles out of it. blocks at GE now getting sleeved
Old Sep 15, 2002 | 10:43 PM
Zero2Sixty's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (Boooooooooost)
Hopefully I not speaking to soon for me but my block is doing fine with 11 psi and it has about 700 miles. But the only reason for me having a b20 is because my b16 cylinder wall cracked.
Old Sep 15, 2002 | 10:47 PM
Ri5e's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (Zero2Sixty)
I know a lot of other people that have cracked the B20 Sleeves. As long as you stay below 12.5 PSI you'll be okay!
Any higher and all the stress will just crack it.
Old Sep 15, 2002 | 11:40 PM
shane's Avatar
i'm just curious if you called around and what the prices you got were on sleeving. I also have to rebuild my b20 bottom end.
Old Sep 15, 2002 | 11:53 PM
Ri5e's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (shane)
I'm gonna make a few phone calls tomorow to see how much I can get for GE sleeves. Gonna buy a GSR block and get it sleeved and bored to 84mm.
Money in, Money out
Old Sep 16, 2002 | 12:06 AM
W.Zero's Avatar
Money in, Money out
that be a real good idea!
Old Sep 16, 2002 | 12:14 AM
Flamenco-T's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (W.ZeroB18C1T)
it's one big huge money pit.....unfortunately we're all in it....hehehe
Old Sep 16, 2002 | 12:18 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: What a sad day. Cracked B20 Sleeves (Flamenco-NA)
Bone stock Ls with stock pistons and rods handle 17psi fine no cranks or anything. Was tuned. Blew a head gasket only when i was redlining 5th gear on the hwy but thats it. Sorry yong come by my house and look at the block. maybe we can work something out like $200-400 who knows.
VaporTrail's Avatar
New User
LS/B20 rod bolts are VERY weak, and their rods ain't strong either
Old Sep 16, 2002 | 01:08 AM
Kamin's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (VaporTrail)
you ran 16psi on stock internals?
if that was deliberate im sorry, but your STUPID.
if it was accidental, ok then. **** happens
but yes the b20 sleeves are crap.
Old Sep 16, 2002 | 04:47 AM
No-Gi's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (KAMiN)
I dont know how you have made it to 7000 post w/o reading
Old Sep 16, 2002 | 05:29 AM
DR. ON POINT's Avatar
Banned
Default Re: What a sad day. Cracked B20 Sleeves (B16aEK)
damn yO
Old Sep 16, 2002 | 05:37 AM
ekb18c's Avatar
IMO 16 psi is way too much for stock b20 sleeves.
Sorry to hear about your misfortune.
Old Sep 16, 2002 | 05:38 AM
chidoks's Avatar
it wasnt stock internals... he said he had JE pistons and eagle rods....look at the first post
Old Sep 16, 2002 | 05:59 AM
FOrSfEd's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (chidoks)
Sorry bro, just don't give up.
Lee
Old Sep 16, 2002 | 06:12 AM
95GS-R's Avatar
- That isn't a nice thing to say to someone that just blew up their motor.
[Modified by 95GS-R, 3:12 PM 9/16/2002]
Old Sep 16, 2002 | 06:21 AM
simple4012's Avatar
New User
dude what happend to your timing belt?
Old Sep 16, 2002 | 06:38 AM
MIKES's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (95GS-R)
Sorry to hear that man. What octane fuel are you running with 16psi? Also what was your compression at? Are you running any standalone ecu? One of those 3 factors caused this problem. No disrespect but your problem is tuning related. The motor detonated while under boost because of the heat in that cylinder. Looks to me like either that injector in that cylinder that crapped out took a **** or your fuel program is not as good as you thought it was. Flow your injectors now that the motor is out and try to address those issues before the next motor goes in. Give a full run down of all your mods so we can really check your setup for issues( including fuel pressure at idle, timing, octane level,spark plugs, etc). Lastly have you ever dyno tuned it or put a wideband o2 on to dial in your A/F ratio, or is it the old seat of the pants method? It sucks when it happens but the good thing is you have time to correct your errors before the next motor goes in.
Old Sep 16, 2002 | 07:20 AM
sutrusu's Avatar
Default Re: What a sad day. Cracked B20 Sleeves (MIKES)
Old Sep 16, 2002 | 07:35 AM
jinxproof99's Avatar
New User
Default Re: What a sad day. Cracked B20 Sleeves (sutrusu)
we've had good luck with the b20 block so far. my friend runs 116 octane and has boosted to 20 lbs. made 352 hsp on the dyno. drives it @ 11 lbs on pump gas everyday.
sorry to here about that BG.
