CRX won't start
Old Jul 21, 2010 | 03:52 PM
90EFadam's Avatar
Default CRX won't start
Yesterday, my 90 CRX quit starting. The starter won't kick. Tested the starter at the local auto parts store and it worked fine there. The battery has 12.4V, and it measured the same from the battery to the starter. Checked the starter signal fuse and its fine. Any ideas?
Old Jul 21, 2010 | 06:42 PM
crex-ef's Avatar
Default Re: CRX won't start
have you checked all your grounds ?
what does your car do?
Old Jul 21, 2010 | 08:30 PM
505sTurborex's Avatar
My car started doing the same ****. I tested the signal wire and i was only getting 6v to the wire not really sure what is or whats doing it and I tested everything on that circuit. So I just ran new a wire to a realy and put in a push button and no more problems.
Old Jul 21, 2010 | 10:30 PM
TJChad's Avatar
Your wire probably just had internal corrosion on the wire. It can drop the other 6v just from resistance (amperage) being pulled from corrosion. This guy most likely has the same problem, he just had to find out if it's the control or feed circuit.
Old Jul 22, 2010 | 06:39 AM
90EFadam's Avatar
thanks for the help, let you know when i get it fixed.
Old Jul 22, 2010 | 11:03 AM
90EFadam's Avatar
today i found half of a rubber stopper on the driver's side floor. and the problem and solution became immeadately clear. The stopper for the clutch interlock switch had broken off. after a quick stop at the parts counter of the dealership its running great again.
Old Jul 22, 2010 | 11:24 AM
TJChad's Avatar
yessir.....control circuit for the starter
LsScivic
Mar 4, 2009 07:39 PM
91crxz280
Jan 3, 2009 11:56 PM
TravisB16a
12
May 16, 2008 04:26 PM
CLE
22
Apr 5, 2006 09:27 AM
mtber
Jul 14, 2004 09:02 AM
