ITR 98 Stock TB Size
Guys,
What size does the ITR 98 spec JDM comes in Throttle Body (Tb) and which upgrade in size and brand would be recommended.
R
R
ITR/CTR TB's are 64mm tapered to 62mm, with a 62mm butterfly.
Look in the sponsor forum. Last I checked there were a couple decent TB's priced around $100 that were in the 68mm/70mm range. Portmatch one of those to your IM and you should pick up a few ponies.
65mm is more then enough for up to 250WHP B series engines.
Higher bore TB will nett more HP at the peak, but engine response is more better and faster with 65mm which will result better performance
Beave0101
May 20, 2003 12:03 AM
