Need help installing air horn....what am i doing wrong?
Old Sep 15, 2002 | 09:34 PM
Dan GSR's Avatar
Default Need help installing air horn....what am i doing wrong?
I think I have everthing right....but its not workin properly.
I have 85 on the relay connected to the positive line on my horn. I disconnected the stock horn and used the line there (blue wire) near the radiator, Is this how I'm supposed to do it?
when i hit the horn button...nothing.....but if i plug in the stock horn back....the air horn turns on....constant (not pressing the horn button)
Dan GSR's Avatar
Default Re: Need help installing air horn....what am i doing wrong? (Dan GSR)
do I need to ground the line from the stock horn?
Old Sep 16, 2002 | 07:35 PM
ScrapinSi's Avatar
85 goes to a solid ground.
30 goes to the battery
86 is where you plug in the factory horn wire
87 runs to the compressor.
That diagram is for a VW which uses a negative output horn (The horn button is ground) but on hondas, they are opposite.
Old Sep 16, 2002 | 10:05 PM
B18C1 for fun's Avatar
Default Re: Need help installing air horn....what am i doing wrong? (ScrapinSi)
disconnect 86 from 30, leave 30 hooked on the battery and ground 86. I relay needs both power and ground to activate. In the diagram you have you have a power going into the relay (85) and also power going into (86).
Old Sep 16, 2002 | 10:11 PM
Dan GSR's Avatar
Default Re: Need help installing air horn....what am i doing wrong? (B18C1 for fun)
Thanks yo...I talked to a friend of mine today...and he said the same thing.....thanks for all the help guys.....it works now
Old Sep 19, 2002 | 12:02 PM
DRxCIVIC's Avatar
hey man where did u get the air horn from? and how much was it? mite lookin into getting one.. i'm tired of the "bitch" horn that came with my car...
solsi2000
Jul 23, 2008 04:26 PM
b20acura
Jul 30, 2007 09:43 PM
Bizarre
Sep 26, 2005 11:58 PM
blackcivic44
May 10, 2005 02:42 PM
cleofis
Audio / Security / Video
Jun 21, 2004 08:01 PM
