ITR valvetrain support skunk2 stage 2 tuner cams ?
Old Jul 20, 2010 | 06:56 PM
99gsvtec's Avatar
Default ITR valvetrain support skunk2 stage 2 tuner cams ?
Have fresh p72 gsr head that has NEW ITR valves, dual springs, keepers, Crower ti-retainers, full port & polish job. Skunk2 stage 2 tuner cams. Car is gonna dyno around 225hp has cp 11.0.1 pistons 82mm & eagle rods, but question is will these valve springs be enough security for my camshafts ? Head is going on gsr block
CAM Specs
Intake Lift Adv. Dur.@.004" @.050"
Primary .375" 317° 199°
VTEC .500" 364° 262°
Secondary .405" 319° 215°
Exhaust Lift Adv. Dur.@004" @.050"
Primary .374" 326° 214°
VTEC .469" 329° 260°
Secondary .374" 308° 195°
Old Jul 20, 2010 | 07:10 PM
slowsleeper's Avatar
Default Re: ITR valvetrain support skunk2 stage 2 tuner cams ?
no
Old Jul 20, 2010 | 07:26 PM
95skunkedgsr's Avatar
big no no
Old Jul 21, 2010 | 07:34 AM
99gsvtec's Avatar
Why is that ? Is the spring rate too soft ?
Old Jul 21, 2010 | 02:41 PM
allmotor-B's Avatar
no... coil bind
Old Jul 21, 2010 | 04:25 PM
00Red_SiR's Avatar
All Motor Mentor
Type R springs are still considered to be STOCK springs, Skunk clearly states that if you run those cams you MUST upgrade to aftermarket springs. Coil bind is one big reason, valve float would be another.
Old Jul 21, 2010 | 08:38 PM
99gsvtec's Avatar
Have similar set up what did ur car dyno not on the juice ? What type of dyno .... Ill just take the valve springs out of my current b18c when I take my skunk2 tuner 2 cams out supposidly they are skunk2 springs & retainers prob supertech, def dual though dude ran pro1s or pro2s before so must be decent
Old Jul 22, 2010 | 03:39 PM
00Red_SiR's Avatar
All Motor Mentor
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/my-b18c5-dyno-graph-m22x-simple-basemap-2132208/
Old Jul 22, 2010 | 05:29 PM
99gsvtec's Avatar
My old set up
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/dyno-results-some-good-s-gsr-2665686/
longfellahh
Mar 8, 2006 05:36 PM
one slow coupe
19
Feb 9, 2006 03:45 PM
grenthang
Mar 13, 2005 11:57 AM
Im-Gay
Aug 16, 2004 06:08 PM
PSU-TEG
Aug 13, 2002 10:36 AM
