Help for cam degree on GSR/skunk2 pro2 cam
Old Jul 20, 2010 | 04:09 PM
SonicB's Avatar
Default Help for cam degree on GSR/skunk2 pro2 cam
hi
been looking pretty long time, my machine shop has some financial issues and guy there doing the blueprint and degreeing motor isn't comming to job in next month and i need my engine yesterday
mods are
B18C1 engine
P72 head
Omni valvetrain, skunk2 pro2 cams, skunk2 pro cam gears, Omni valves (std size), CP 81.50 pistons, eagle rods, cometic gs..etc which is not needed for this info....
if needed more info on setup please don't hesitate to ask
Does anyone has some reccomendation for camgears degree settings.
Any similar setup on engines like this...
please help this last two weeks i'm like on needle
Old Jul 20, 2010 | 04:51 PM
teg_racer's Avatar
Default Re: Help for cam degree on GSR/skunk2 pro2 cam
its either +4 or +5 exhaust and +1 intake
Old Jul 20, 2010 | 05:10 PM
00Red_SiR's Avatar
All Motor Mentor
on those gears you'll want something like +1 Intake and +3 Exhaust or 0 Intake and +4 exhaust. Until you know what your V2V (valve to valve) clearances are, you'll want to maintain 4 degrees of seperation when adjusting those cam gears to their final settings.
Old Jul 20, 2010 | 06:03 PM
raverx3m's Avatar
heres the insert that comes with cams in pdf format
http://www.skunk2.com/installation/305-05-5145.pdf
Old Jul 21, 2010 | 01:31 AM
SonicB's Avatar
by your experience s2p2 cams always has 4 degrees separation with pro camgears even tuned ?
Old Jul 21, 2010 | 01:12 PM
00Red_SiR's Avatar
All Motor Mentor
In some cases yes, maybe most, it is what Skunk 2 says you should maintain. Unless you know exactly what your valve to valve clearance is, it isn't considered safe to use less than 4 degrees of seperation between your adjustments when tuning. I measured my clearances and go less seperation but others checked theirs and cannot. So it's not a one size fits all adjustment.
LS AzZkIkr
Sep 20, 2008 07:27 PM
DavidT or VajT
Apr 3, 2005 06:32 PM
anothersickhatch
Sep 7, 2004 11:32 AM
tbud454
Jul 28, 2004 11:13 AM
