What´s the most appropriate way to build a Ls-Vtec for Off Roading?
Hi guys, I´m sure that most of you have heard about the "Baja 250, 500 and the Baja 1000". For those who don´t know anything about off-roading... here´s a video:
http://www.youtube.com/watch?v=FGA1V31_1Cs
Now, I have read a lot of threads about engine builds, but I´ve never seen one talking about off-road engines (baja or desert races). How should I build a reliable engine that will last at least 1000 miles of pain?
What info am I looking for in this thread?
-Oil pan mods are required?
-ECU mods are required? (I´m sure it´s a must... but I´m talking about eliminating censors and stuff)
-How would "jumping" affect the engine? (Would it loosen up the bolts from the crank, head, etc?)
Any info is appreciated...
Thanks in advance.
Thanks in advance.
^this...maybe add an accusump to try to ensure it never starves for oil as it's bouncing around.
(just be sure the cutoff valve for the accusump is somewhere easy to get to so you can shut if off in the event you cut an oil line and find yourself dumping 5-gal bottles on it to try to put it out...had a friend do this recently - kept emptying extinguishers on the burning lines but the fire wouldn't go out...afterwards realized the accusump has not been shut off and just kept pushing more oil into the cut lines and feeding the fire)
This is probably not a question that can be answered in a thread on the internet.
Depends on how deep you want to go. Like accusump for example, good idea, however most of those guys are using dry sump oiling to fix oil sloshing / cavitation / temperature control.
Look for books on the subject, and talk to people at the races, see what they have to say.
you know the B16 is fairly popular in the 1600 class. alot of people run them. unfortunatly I cannot point you in the direction to help out. best bet would be some baja forums or at the events.
Mjalaly
13
Oct 19, 2017 06:08 PM
