EP3 Kswap
So a buddy has an EP3 and bought a typeS motor. He wants to swap it. I'm assuming this is all plug n play minus the ECU. Mounts and tranny will work although it's only a 5 speed right?
you will need to see if his EP is one of the ones that got the unlocked shifting track for the 6th speed t... if not you will need either the BC SS kit or there is a dyi on ephatch but I wouldn't recommend it! Oh and you need to figure out how you want to go about the reverse lockout.
^^So the mounts etc will work? Will there be issues with this reverse lockout? I'm going to assume BCSS is a Buddy Club Short Shifter? Will this resolve the issue entirely? How do I find out if the OEM shifter has a reverse lockout?
Why the need for kpro? I think this guy wants to keep it entirely stock for the most part. Is there an issue with the immobilizer? Acura should be able to reprogram it right?
Since the EP3 uses the PRB IM like the K20A2 engines, everything will swap over and all sensors and plugs will work perfectly fine with the stock harness.
You will need the Kpro to take full advantage of the car and maximize power, and the EP3 map on the ECU CANNOT be flashed to the RSX-S.
No issues with axles or anything like that. But I do suggest that when dropping the motor, drop the subframe too, made it easier for me.
I'm not going to say this to be mean but just to prove a point to all members you guys!
This thread will answer most of your questions... sometimes just a few minutes of searching will give you your answers you are looking for!
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/everything-you-need-swap-k20a2-into-ep3-2410236/
