How to flush radiator
Old Sep 15, 2002 | 08:22 PM
LoooseGSR's Avatar
Default How to flush radiator
As topic says...I'm having trouble finding where to drain it from...my radiator fluid is pretty dirty...want to do this before winter hits.
Old Sep 15, 2002 | 08:56 PM
EP3_05's Avatar
Default Re: How to flush radiator (PSUCRX)
If you look at the bottom right of the radiator pictured in the diagram you will see the drain plug.
Hope this diagram helps you out a bit.
Old Sep 15, 2002 | 09:07 PM
JDM88EF9's Avatar
Default Re: How to flush radiator (91civic)
Nice! Now I know where it is......I just got the car and don't know where everything is at just yet...
Old Sep 15, 2002 | 09:25 PM
bryant's Avatar
Default Re: How to flush radiator (JDM88EF9)
its a butterfly nut on the bottom left hand side (passenger side) of the Rad.
Old Sep 15, 2002 | 09:34 PM
JDM88EF9's Avatar
Default Re: How to flush radiator (CR-X)
Do you twist it or use a wrench or something like that?
Old Sep 15, 2002 | 09:37 PM
bryant's Avatar
twist. but if its tight on there you can use pliers (sp)
Old Sep 15, 2002 | 09:39 PM
JDM88EF9's Avatar
Ok... Thank's a lot man!
Old Sep 15, 2002 | 11:24 PM
LoooseGSR's Avatar
Awesome...BTW do i have to take off that splash guard under the front end to get to it? or is there an access panel?
Old Sep 16, 2002 | 03:22 AM
HF2ZC's Avatar
Yes, you do have to take off the splash guard.
Old Sep 16, 2002 | 08:06 AM
LoooseGSR's Avatar
Default Re: How to flush radiator (HF2ZC)
Is there a trick to doing that? I can't remember if there are clips or you just unscrew some screws.
Old Sep 16, 2002 | 08:36 AM
bryant's Avatar
its just some skrews
Old Sep 16, 2002 | 09:57 AM
carsaregood's Avatar
does anyone know where the drain bolt/plug is on the block? or is there one? is it different on different motors (d-series)? thanks. and how do you guys go about "flushing" the system? do you just drain, refill, and repeat? just curious about learning some better, more effective techniques.
Old Sep 16, 2002 | 10:06 AM
MADEINIRAQ's Avatar
Default Re: How to flush radiator (carsaregood)
the drain bolt on the block is on the front to the right of the engine code.. it's a bolt . can't miss it
Old Sep 16, 2002 | 07:15 PM
JDM88EF9's Avatar
Default Re: How to flush radiator (madeiniraq)
I flused my radiator today and it was so easy. Once I unscrewed the butterfly screw I just oped the radiator cap and that bad boy poored... I didnt even go under the car to unscrew it, I just looked in the engine bay and can see it then just reached under the bumper and bam done!
Old Sep 16, 2002 | 07:46 PM
SOHCwarrior's Avatar
make sure you bleed it to get all the air bubbles out
Old Sep 16, 2002 | 07:51 PM
JDM88EF9's Avatar
Default Re: How to flush radiator (SOHCwarrior)
ok!
Halo
Mar 18, 2012 10:15 PM
vtecmw
Dec 5, 2005 09:44 AM
HatchBox
Apr 15, 2004 06:26 PM
btole
Mar 24, 2004 09:52 AM
uNF$@#!
Jun 24, 2002 10:06 AM
