Injectors
Old Sep 15, 2002 | 08:19 PM
95c1v1cs1's Avatar
Default Injectors
Will a set of rc intectors off of a obd2 b16a2 fit into a b18c obd1 intake mani? Does the actual phsical size of the injector fit and will the plugs on the harness work. I spotted some really cheap ones and wanted to make sure they will be ok before i buy.
Thanks in advance for the votes or posts.
Corey
Old Sep 16, 2002 | 01:10 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Injectors (95c1v1cs1)
All you had to do was call RC, and you would have found out that all RC injectors are OBD1 only. For OBD2 cars, they have to change out the injector clips, and then install them.
To answer your question, yes, they will install, and plug & play with no problems.
Old Sep 16, 2002 | 08:10 AM
95c1v1cs1's Avatar
Default Re: Injectors (B18C-EJ1)
Thanks
import-tooner
Mar 11, 2015 03:43 PM
jayswizz
Feb 14, 2014 10:06 AM
SiR99
Apr 29, 2006 10:18 AM
Franky
Aug 25, 2004 12:30 PM
aesthetics82
Apr 2, 2003 05:39 AM
