Tire hum
Old Jul 20, 2010 | 08:15 AM
hotchef181818's Avatar
Default Tire hum
The noise started when I lowered the car, tokico blues and H&R sports springs. Its a 02 2 door. The noise gets louder as I speed up, goes away in a sweeping left turn on the highway. I'm gonna try to find the numbers from when it was aligned. Is the camber just way off? I swear its coming from both rear tires. Thanks
Old Jul 20, 2010 | 05:25 PM
sgraham01's Avatar
Default Re: Tire hum
toe setting is most important, make sure it's in spec. camber itself should not cause a hum. improper toe will cause tire scrub which should cause noise. toe should also be set after camber adjustments. you can check your toe "roughly" with a plumb bob and tape measure to see if it's anywhere close. I actually do this for my toe settings and I can seem to get it in spec. Haven't had any issues with tire wear yet.
Shake and Bake
17
Mar 2, 2006 09:10 AM
descartesfool
11
Jun 26, 2004 09:55 PM
blurrrcivic94
May 5, 2004 06:59 AM
bleeedawg
Oct 30, 2003 11:48 AM
