Need a measurement from an EK Front Upper Control Arm...
I'm replacing some front upper control arm bushings on a '00 EK coupe and I unfortunately pressed all of them out while the press was set up for removal before getting the measurement of the seat depth. As people who have done this before know, the UCA bushings don't have a tapered seat, you can push them all the way through in either direction.. I found out the hard way that you need to measure that first
The car isn't coming off the stands for at least a week, so not a huge deal, but if anyone has any OEM front EK Upper Arms lying around, please measure "A" as labeled in this picture for me. The diagram implies that they are different all the way around, but afaik they should be the same.
Thanks in advance
Thanks in advance
HondaBondMan
Feb 7, 2007 08:07 PM
