Fuel Pressure Regulator
Old Sep 15, 2002 | 07:58 PM
SuPeRITR's Avatar
New User
Default Fuel Pressure Regulator
i just bought a set of Toda B cams, Portflow valvetrain, and RC 310 injectors. I was wondering what kind of FPR i should use. I have heard that the AEM sucks *** and i dont want anything that is bad on my car. Thanks in advance!
Old Sep 15, 2002 | 08:00 PM
AssPenny's Avatar
Default Re: Fuel Pressure Regulator (SuPeRITR)
B&M ownz
Craig - Whos still gota order some junk for his b's
Old Sep 15, 2002 | 08:03 PM
Casey's Avatar
Default Re: Fuel Pressure Regulator (AssPenny)
how does the aem suck ***? i have it on my car without any problems
Old Sep 15, 2002 | 08:11 PM
SuPeRITR's Avatar
New User
Default Re: Fuel Pressure Regulator (CWTypeR463)
I dont know its just what i have heard from talking to some guys. I guess if its worked for you then there is nothing wrong with them. A lot of people have mixed feelings about them.
Old Sep 15, 2002 | 08:13 PM
Casey's Avatar
ive heard mixed feelings about the b&m as well, untill i see solid proof that either sucks id go with whichever one you want, i went aem cuz its bolt on and didnt need to drill in(i think you have to do this with b and m, its late, cant remember)
Old Sep 15, 2002 | 08:15 PM
SuPeRITR's Avatar
New User
thanks for your .02 i appreciate it.
vtec.dc2's Avatar
are you sure they weren't reffering to aem cam gear bolts?
both aem and b&m f.p.r are good..
i think aem is easier to install due to less parts to put together and is more money due to the name
Old Sep 15, 2002 | 11:01 PM
frogsr's Avatar
it's late, but you don't need to drill anything for b&m. some cutting, yes.
Old Sep 15, 2002 | 11:02 PM
92TypeR's Avatar
FSAE
Default Re: Fuel Pressure Regulator (frogsr)
B&M
Old Sep 16, 2002 | 06:19 AM
mstewar's Avatar
i had been recommended to use Walbro when I had a JRSC Si.. I would assume it would be just as good for an NA setup..
AEM is a big name, but their FPR is rumored to have problems.. never heard anything bad about the B&M until i saw this post though!
Old Sep 16, 2002 | 06:27 AM
Rob :190:'s Avatar
Default Re: Fuel Pressure Regulator (mstewar)
one of the brands cant be adjusted below stock fuel pressure levels or something. dont know which one.
Old Sep 16, 2002 | 06:41 AM
RTW DC2R's Avatar
Default Re: Fuel Pressure Regulator ( Rob)
Only problem I had with the AEM was one of the bolts(where you should mount the gauge) was leaking gas, but that was nothing a lil Hondabond couldnt fix.
Acura_I-RS
Jun 7, 2004 06:22 PM
Prelude Vtec 23
Jul 16, 2003 10:10 PM
turbochic
May 15, 2003 06:29 PM
not133t
Mar 6, 2003 08:55 AM
Casey
Feb 28, 2002 09:41 PM
