Car stalls after reaching operating temp
Old Jul 19, 2010 | 05:42 PM
neoc03's Avatar
Default Car stalls after reaching operating temp
Basic Rundown:
Car is a 2000 Honda Civic SI. Turbocharged running eCtune. Just replaced fuel filter so I know that isn't causing the issue.
Here is what happens:
When car is cold it starts right up runs like butter holds perfect idle.
Once it reaches operating temp I will be pressing the gas and all the sudden loses all power. You can hear it start to sputter really bad for about 3 seconds then it just cuts out. The car won't start back up while it is still at operating temp. However once it reaches a temp below that it fires right up and acts just fine.
Any Ideas?
Old Jul 19, 2010 | 05:44 PM
Former User's Avatar
Default Re: Car stalls after reaching operating temp
Any CEL codes?
Check whether unplugging the primary O2 sensor eliminates the problem.
Old Jul 19, 2010 | 05:55 PM
hondamark35's Avatar
i've had similar symptoms with a 91 Integra recently. after a lot of tail chasing... i discovered the cat. converter was 80-90% clogged! the 'honeycomb' material had melted. i haven't test driven it with a new cat yet, but with the way that one looked... it's no wonder it struggled!
drop that cat down and have a look.
Old Jul 19, 2010 | 06:11 PM
neoc03's Avatar
No CEL as usual. CEL light is working. I will try unplugging the 02 sensor first thing tomorrow. I did some reading and saw that going into closed loop and the 02 sensor is on it's way out it can cause these problems. Shouldn't that kick a CEL though? Will the car run fine with the primary unplugged since it's a specific written tune? Thanks for the quick reply.
Old Jul 19, 2010 | 06:12 PM
Bad O2 sensors don't necessarily throw a code.
Old Jul 19, 2010 | 06:17 PM
neoc03's Avatar
Cat is gutted so I know it's not that. So what will the car do when it reaches operating temp and doesn't get any input from the 02 sensor it's looking for?
Old Jul 19, 2010 | 06:20 PM
Stock set up would just run rich after unplugging the primary O2 sensor. Not sure what the effect will be on your tuned set up.
Old Jul 19, 2010 | 06:49 PM
neoc03's Avatar
So if the car runs fine it's obviously the 02 sensor.
Old Jul 19, 2010 | 07:00 PM
Yes
Old Jul 19, 2010 | 07:03 PM
neoc03's Avatar
Thanks for the help again.
Old Jul 20, 2010 | 01:04 PM
neoc03's Avatar
Just as a follow up the primary was already unplugged and capped. I unplugged the secondary and like magic it's behaving again. Very rich though to the point I can smell it at a stop light. New downstream sensor comes in tomorrow.
Old Jul 20, 2010 | 01:07 PM
The secondary O2 sensor has no function whatsoever in determining the air:fuel ratio. Therefore, my guess is the primary and secondary O2 sensors are swapped and that the secondary O2 sensor was originally unplugged. Double check the wires.
Old Jul 20, 2010 | 08:00 PM
farfrumugen's Avatar
ignition module
Old Jul 20, 2010 | 08:04 PM
Originally Posted by farfrumugen
ignition module
This is definitely possible.
Old Jul 20, 2010 | 08:28 PM
neoc03's Avatar
The wires ran up into the cabin right above the 02 sensor after the cat. The actual pigtail connection was inside the car right behind the cupholders. The pigtail wouldn't be able to reach the primary sensor. Car was just at the tuners for headwork. I guess they may have just left it unplugged on accident. I'll crawl back under there tomorrow.
What function does the secondary 02 sensor serve?
Old Jul 20, 2010 | 08:38 PM
What are the four wire colors leading from the wire harness connector of the primary and secondary O2 sensors?
You might want to try reconnecting both O2 sensors to see what happens.
The secondary O2 sensor serves only to monitor whether the catalytic converter is properly reducing emissions.
Rexfx
Jun 23, 2009 05:22 PM
whitecivic11
Oct 29, 2008 09:38 AM
Gronked
Oct 29, 2007 06:12 PM
T0rqueless
Mar 3, 2006 01:07 PM
DBallz
Jul 29, 2003 10:04 AM
