F/S IN Complete B18C1 swap with extras
Up for sale is a complete swap out of a 98 GSR. Motor has good compression on all cylinder and is still in the vehicle is anyone locally want to come ride/drive/hear it run. Trans is good with no grinds. Fluid changed with honda fluid every 20k or so. Oil changed every 3k. Fresh timing belt and water pump. Comes with everything you need to swap. Includes wire harness, trans, ecu, PS pump, alt., ac compressor shift linkages and complete motor. Heres the goodies you get with it, all of which were installed just this spring.
Skunk 2 Intake manifold
outlaw engineering thermo spacer
password jdm kevlar intake
MSD external coil, wires, cap and rotor
Innovative mounts, billet, black, 75a
Hytech replica header
Hondata S300 installed and tuned
Drive shaft shop stage 0 axles
and some other misc things here and there.
Please send me a PM and I will get back with you as soon as I can. Located in Indianapolis. Asking 3k for everything. Thanks!
eghatch9295
Jul 14, 2013 08:13 PM
